07-19-2015, 10:56 AM | #1 |
Parking Brake Light Stays On
Does anyone know why my brake light on my dash stays on even after I release it?
07-19-2015, 11:18 AM | #2 |
Re: Parking Brake Light Stays On
Maybe that brake light isn't for your park brake!!
It's for your prop valve! Tells you you have a failure in your master cylinder. |
07-19-2015, 11:36 AM | #3 |
Pull up on the parking brake pedal and see if it goes out.
It could also be an indication of brake problems. |
07-19-2015, 12:59 PM | #4 | |
On a side note, there is a diy thread on the forum on how to make the brake light function with the e brake. It's a really cheap and easy mod. |
07-19-2015, 01:16 PM | #5 |
The Older Generation
As the others have said that light has nothing to do with your parking brake. Take the cover off of the master cylinder and I will bet that one of the fluid chambers will be dry. That means you have a leak in either the front or rear brake lines or wheel cylinders..... LockDoc
07-21-2015, 09:51 PM | #6 | |
07-21-2015, 11:08 PM | #7 |
If you don't see any fluid leaking from any of the rear lines you will have to pull the rear drums off to see which wheel cylinder is leaking and replace it.... Wait! Is this a C-10 or C-20???
LocDoc
07-26-2015, 10:55 AM | #8 |
07-26-2015, 05:09 PM | #9 |
My light is one too, rear reservoir is almost empty. Investigated a little more, both rear wheel cylinders are leaky! Not so good...thanks guys
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
