09-23-2015, 09:23 AM | #1 |
But Found Her 25yrs Later!
60-62 Frame Horns
Common problem with them cracking and breaking.
I had hoped to replace them with the 63-66 style, but it's not just about the bolt spacing, the 60-62 bumper contour is different than the 63-66. I know I could find someone who has a nicer set they could cut off an old frame, but I'd like to see if we could come up with another solution. Has anyone fabricated their own new horns?
09-23-2015, 11:28 AM | #2 |
Re: 60-62 Frame Horns
I actually made it this far before I realized the shape of the bumpers are different. I knew the bolt spacing was different, but I didn't realize the shape of the bumpers on 63-66 were different from the 60-62.
09-23-2015, 11:33 AM | #3 |
You've gone that far, why not just find a 63-66 bumper to fit the new horns? Or am I missing something?
09-23-2015, 01:45 PM | #4 |
They're not welded yet. Just hanging there for mock up.
Yes, I've considered getting a 63-66 Chrome Bumper. I've got one more thing I'm going to try. I would rather not spend $180.
09-23-2015, 02:02 PM | #5 |
Isn't the 63-66 frame taller here ? Might interfere with the grille surround . The notches in the surround for 63-66 are taller or deeper than 60-62.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
09-23-2015, 02:08 PM | #6 |
yes, my grill support happens to be from a 65. my 65 is on a 62 frame.
09-23-2015, 04:09 PM | #7 |
I'll chalk it up to another lesson learned.
No big deal. I went ahead and repaired the 62 horns. I'm comfortable with my welding skills. I'll just weld them back on.
09-23-2015, 10:47 PM | #8 |
Active Member
My front frame horns are shot too so if anyone has '60-'62 horns or another solution, please reply.
03-05-2016, 11:55 AM | #9 |
I cut mine off. Bolted the broken pieces to the bumper. Tack welded the pieces together. Then welded the repaired horns back on.
03-05-2016, 03:40 PM | #10 |
I would weld in some gussets to keep it from happening again.
11-08-2018, 04:59 PM | #11 |
Yes, I just want to do few more alignment checks before I reinforce them.
06-21-2021, 05:37 PM | #12 |
It's almost like there should be a reinforcement piece that could be fabricated to bolt to the existing frame. That way even those without the ability to weld could just bolt it up.
04-05-2018, 07:02 PM | #13 |
Saving ron's post for future reference:
04-22-2018, 01:02 PM | #14 |
I am in the same predicament. I currently have a set of frame horns from a 63-66. If I welded those on to my 60 Chevy would I just have to use the 63 to 66 bumper?
10-08-2018, 11:57 PM | #15 |
Yes
