09-24-2015, 10:15 PM | #1 |
4.8 4l60e vs 4 or 5spd
I'm looking at buying a 99' 4.8l engine, I would love to stay with a manual transmission but i want something that will run down the highway and still get in the 20's cruising. So I have a few direct questions if anyone could help me out.
Is anyone running an m20 or m21? Whats the 5spd that came with a 4.8l? Is anyone running one? What crossmember is used? Do i need to install a high hump?
Opportunity is missed by most because it is dressed in overalls and looks like work. - Thomas Edison |
09-25-2015, 07:14 AM | #2 |
Re: 4.8 4l60e vs 4 or 5spd
Hopefully this will get moved tot he LS swap section. You will get a lot more exposure and answer over there.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
09-25-2015, 07:17 AM | #3 |
I'm hoping it does, that's where I originally thought I posted.
09-25-2015, 09:44 AM | #4 |
I believe the manual trans used with the 4.8 is the NV3500. They're pretty decent as long as you're not planning to really beat on them. You'll have to search to find them, though. Apparently, Americans have become to lazy to shift their own gears anymore, so GM didn't build very many.
09-26-2015, 01:07 PM | #5 |
Yes, I think the 5 speed is a NV3500. It's good to around 300 ft-lbs. Not much else to say about it except that it's a PITA to rebuild one, from what I've read.
The big advantage of a NV3500 vs a M2x 4-speed is the overdrive, of course. Without overdrive the 4.8 won't be making enough torque to get any performance *and* run 70+ mph at a cruising RPM. You'd have to pick one. I wouldn't want to run the 4.8 without overdrive and steeper gears in back, it would be kind of a let-down in a hobby truck. I have a 2003 4.8 + 4L60e and 4.11 gears in back of my '57 longbed. It's fun and the overdrive lets it loaf on the highway. When it drops to third it takes off and makes you smile.
"Over my head" 1957 Chevy 3200, big rear window & 6 lug. Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina. |
10-12-2016, 08:13 PM | #6 |
I've got a NV3500 behind my 4.8l its not a track truck by any means but being out in NC and cruising at 60 mph or even 70...that 5th gear ratio is amazing!
10-12-2016, 08:16 PM | #7 |
i cut out my floor and put a high hump.
made my own crossmember to support the nv3500, and it came out of a 92-93 Silverado. hydraulic clutch is nice and smooth had to buy special pilot pushing for input shaft but worth the hassle, can look up part number if needed, and flywheel and clutch were for a 4.8l motor |
10-12-2016, 08:27 PM | #8 | |
10-12-2016, 09:46 PM | #9 |
I have and drive manual 4 and 5 speed Muncie M20 and Tremac TKO600 and 4L60E
and have for many years........ no question the 4L60E is the only to go
10-13-2016, 12:38 AM | #10 |
I used allllmost the same ideas he did in post #16...
Just search nv3500 in the forum man, im at work and dont have all my photos. I'll try and get them |
10-13-2016, 02:13 PM | #11 |
Hi there, I recently put in a 2002 6.0l in my truck with a M22 behind it, I did not need to install a high hump the clearance was more than enough with the low hump floor. For crossmember I used this unit that I got from summit. I had to drill new holes in the frame, but other than that a perfect fit. https://www.summitracing.com/int/par...9427/overview/
1978 SWB cheyenne A/C, power steering/brakes, 305, Tach, Gauges 1972 SWB Custom 10, gauges, cammed LQ9, M22 |
10-17-2016, 07:13 AM | #12 |
Im running a late model nv3500 in my 1966 k10. great trans and holds up well behind my 292 inline 6. I also swapped in a hurst shifter and recommend it. I used a stock hydro internal slave cylinder and a 3/4" wildwood master cylinder with a stainless line between the two.
