12-15-2015, 09:17 PM | #1 |
Are the Door Panels the same??
...wondering if the 67-71 door panels will interchange..I have a 67 GMC and I really like the 69/70 pattern..plus I'm going to install power windows so I guess my concern is if the door handle hole matching up, right?
12-15-2015, 11:02 PM | #2 |
Re: Are the Door Panels the same??
you betcha
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
12-16-2015, 11:00 PM | #3 |
...Yo BowTie..does "you betcha" mean Yes the panels will fit? or "my concern is the door handle fitting"..either way..Thanks!
12-17-2015, 03:56 AM | #4 |
yes and yes. they will interchange between 67 and 71. they are all the same steel panel, just have different vinyl coverings. so the door handle locations should match up.
12-17-2015, 02:13 PM | #5 |
12-17-2015, 09:40 PM | #6 |
...what about 1972..wonder if they are the same size??
12-17-2015, 09:53 PM | #7 |
'72 door panels are the same size length and height but differ in depth. In '72 the General went to a plastic sculpted or contoured panel which necessitates use of a deeper or longer window crank mechanisim. Also uses a '72 only arm rest that will not inter-change with previous years.
Also there is a differance in '72 only doors. They will have a factory drilled or punched hole just below the vent window. Uses a screw to better support the vent window channel.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
12-18-2015, 03:32 PM | #8 | |
