01-06-2016, 08:17 PM | #1 |
Harmonic balancer
In the process of my 350 build and was wondering how does one go about choosing the correct harmonic dampener. There was not one with the block when I got it. Its an 86,87,OEM roller block,1 piece rear main seal.. Looking at summit, I see internal and external balance .
01-07-2016, 12:13 AM | #2 |
Re: Harmonic balancer
Depends on what crank your running, if it's internal/external balance from the manufacturer. I'm assuming it's a gm crank, I believe the 1 piece uses a internal balance balancer and a external balance flywheel. If your not sure take the rotating assembly to a machine shop. Might not hurt to have it checked out, and they can let you know what you need.
1979 Sierra Classic Heavy-half 1996 Silverado x-cab "the daily" |
01-07-2016, 12:58 AM | #3 |
*** That's interesting ***
Right, I agree, normally a 1-piece seal stock crank cuts into the counterweight space, so additional balance weight is needed on the flywheel. But front balancer is neutral. On a truck, I'd run a 8".
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
01-07-2016, 01:24 AM | #4 |
60-66 Nut
Additionally the timing mark on the balancer will need to correspond with the timing pointer being used.
01-07-2016, 02:04 AM | #5 | |
I also second the advice of taking it to a machine shop. If this is an unknown engine, the right thing to do is balance the whole rotating assembly together as a unit (flywheel, crank, balancer, et al). I know that's not ideal in this case if you are already far along, but that's exactly what's done when the engine is built. That being said, you should be OK with bolting on a new balancer and skipping that step. No need to create more work and spend more money. But if you have a vibration, you will be pulling it back out and doing that anyways...
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... Last edited by storm9c1; 01-07-2016 at 02:10 AM. |
01-07-2016, 08:16 AM | #6 |
Thanks guys. I'm a little beyond just grabbing it and running it to town, but I will be headed to the machine shop that done the work on it this morning.
