Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Old 01-25-2016, 11:15 PM   #1
tlman
steering column
trying to figure out other than stock ,,which steering column is closest to fitting a 67-72 any ideas?
tlman is offline   Reply With Quote
Old 02-13-2016, 11:00 PM   #2
fredm98
Active Member
Re: steering column
You can use one from a Chevy van up to I think a 79. Not positive on the year. I got a tilt one from a 76 and it didn't have the key in it so worked perfect.
fredm98 is offline   Reply With Quote
Old 08-07-2016, 01:14 AM   #3
izzy_Britton
izzy_Britton's Avatar
Re: steering column
Why are you wanting to change out your steering column?
I too am looking because i need a column that is situated closer to the dash.
subscribed.
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 05-03-2017, 02:02 PM   #4
sackracing
sackracing's Avatar
Re: steering column
I found this on a google search yesterday. I am going to try to do this with mine this weekend.
http://67-72chevytrucks.com/vboard/s...d.php?t=191143
sackracing is offline   Reply With Quote
Old 05-12-2017, 11:18 PM   #5
68c10airstream
68c10airstream's Avatar
Re: steering column
Sackracing, just for info sake, the intermediate shaft (the shaft under the hood connecting column to gearbox) is plastic injected because it's designed as a break away feature needed when in a head on collision! If i was doing this mod i would cut it off right down at the rag joint area, remove the amount you want to move the column, and as you weld it back up keep the shaft cold with wet rags/and or ice cubes. This way you will retain the full amount of collapse the engineers designed into it, and not melt the plastic!
My mother was in a head on collision in a 74 saab and the seat belt didn't latch and she was impaled against the steering wheel. She held the wheel so hard that her hands were pinned against the sides of the column because she bent the wheel forward!!! I knew the intermediate shaft could collapse and it did as i inspected it once i got the mangled hood up. I can just imagine the steering wheel being forced up at her if the shaft was solid or shortened or incorrectly modified.
My wife can vouch for the many times i ***** out loud at the times i see in a magazine or on tv the double "D" shaft running between 2 u joints connecting a steering rack to a column and have no provision to collapse. Sorry for the rant but if i can reach one person and get them to re-think the process, mission accomplished!!
68c10airstream is offline   Reply With Quote
Old 09-07-2019, 11:48 AM   #6
Duck1
Re: steering column
Without the plastic. I think it'll collapse easier?!.
Duck1 is offline   Reply With Quote
