Blazer gas tank in C10??
I need a new gas tank for my LSx swap on a 1985 C/10 SWB. I can get this 1990 blazer tank. Is this a direct bolt-in on the pickup chassis? I know the fuel inlet will need to be relocated, but I can get it for nothing.
Anyone know how many gallons the blazer tank is.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
![]() ![]() Join Date: May 2015
Re: Blazer gas tank in C10??
If I remember right my 82 blazer had a 25 gallon tank on it..I think they had a 30 gallon also...I would need a big ladder to put gas in that one..ha ha
I don't know if it will "bolt in"..if your tank is good I would consider keeping it and running external pump...that's what I did on mine and I've had no problems...
![]() Join Date: Sep 2007
i just read thread where people use the 87+ tank for their ls conversion. i was thinking of doing this also.
1967custom |
The only difference between the 1987 tank and the earlier ones is a small pan welded to the bottom inside. Must be a baffle but the donar truck I used for the LS motor didn't have any baffle inside its plastic tank.
Your donor truck didn't have baffles in the tank because they use a fuel bucket type sender. The bucket keeps fuel at the pump at all times. You really need some kind of baffle in a tank with an in tank mounted pump if it doesn't use the bucket type sender. For the price of a new '87 tank, around 80 bucks new, I would go that route before trying to adapt a blazer tank that you don't know what the inside looks like. Some things are not a good deal even if they are free.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#7 | |
I wish the donor fuel sending unit with pump would work in my '85 tank. That would be nice.
so let me get this right.. I can take a fuel pump out of my doner veh. 0(03yukon) an it will sit right inside the blazer tank? 87 and up right?
1967custom |
For the price, I just bought a new 87 pickup tank and sender, the EP381 pump drops right into the sender and plugs into the harness. Like a glove.
#10 | |
You need the sending unit from an 87' and an ACDelco EP381 pump (which fits directly into the 87' sending unit as mentioned by MalibuSS). I used a Walbro pump instead of the EP381, but the concept is the same: ![]() ![]() Here is the baffle in the 87' tank: ![]() Fully assembled: ![]() |
Those tanks are not blazer tanks. I want to know more about the blazer tank swap to. im also hearing they hang to low for bag trucks, is that true. i have a 5.5/7 static right now but swapping to porter built stage 2 kits. any pics and help please
#12 | |
Here is an article with pictures about the Blazer tank swap, might give you the info you need for size/depth. http://www.captkaoscustoms.com/blazertank.html |
I used a 92 blazer tank kit in my build. No its not a direct bolt in. was quit a bit if modification, but I like the way it came out
http://67-72chevytrucks.com/vboard/s...d.php?t=649661 |
Did you have to cut the frame anywhere for it to fit ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#15 |
Yes, there was a lot of frame trimming. 1/4 inch to 1 inch in some places
#16 |
i think the tank may hit the ground when im all done and air my bags out. it does hang low
#17 | |
#18 |
Hello to all. LS1nova71 is correct. trust his expertise. He would know. The cheap option is for you, I think, is to use the stock, in-cab tank, with a external fuel pump. you can also modify the stock, in-cab tank and regulator, and use an internal fuel pump. To make the in-cab tank work, I modified the stock, Fuel sending unit with a feed and return, with AN fittings, while using an external fuel pump. My buddies hate in cab tanks so I eventually removed the in-cab tank, bought a fuel cell, and installed the fuel cell behind bridge, for my air bag suspension. good luck. Clark.
#19 |
This is the best idea for an In-cab fuel tank. Check out Dayj1. He has a great thread "Another way to skin the cat; the High Torque 292 LS swap",
with some useful ideas. check it out. |
