![]() Join Date: Oct 2011
How do i measure
I need a formula on how to measure for a static drop lowering kit for my 72. Any help would be appreciated
69 C10 long box All factory 55 Lincoln Capri 50 Buick Hardtop sled 30 Tudor sedan |
![]() Join Date: Jan 2011
Re: How do i measure
There are no formulas for drop. To many variables on what has been changed around or settled with age on these trucks. Are you trying to find out how much your truck has been dropped?
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Not at all. I am trying to figure out what size drop to install. Where or how should i use a tape measure to determine my numbers. I am running 18's on the front and 20's on the back with very low profile tires. The suspension is all stock on a half ton long box 72
The wheels and tires will influance the drop some depending on the offset and the width. Post some pics of your truck and what your goal is for the final ride height. Do you just want the wheels to look good in the wheel wells or get it in the weeds?
Jimmy
I just want the fenders slightly above the tires. I will post the pic's first thing in the morning along with the tire size info. Thank you sooo much friend
If you still have the factory springs in your truck they do sag over time,Being so buying a drop kit you might not get as much as you think because of spring sag.
With pictures and tire heights it can be compared to trucks with known new components. I thinking with 2" drop springs, 2 1/2" drop spindles and 4 or 5" rear springs it will end up close.
Jimmy
