Old 03-21-2016, 10:58 AM   #1
tucker69
tucker69's Avatar
"Fast" intake flexing
Does anyone have any knowledge/experience with the "Fast" LSXRT Intake flexing at the throat when the throttle is opened? i.e. as engine rpm rises the throat of the intake at the throttle body will push outwards. really freaked me out the first time I saw this. it just doent look right. I called "Fast" but didn't get much help. Thanks Casey
tucker69 is offline   Reply With Quote
Old 03-21-2016, 02:12 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: "Fast" intake flexing
Like its physically deforming under load? Its a composite intake, but having enough flex to actually deform would throw me for a loop as well.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-21-2016, 05:37 PM   #3
tucker69
tucker69's Avatar
yes it is actually changing shape. I thought maybe I had a vacuum leak, I checked for that. has to be in the strength of the neck. as engine losses vacuum. however I would think it would pull in instead of pushing toward throttle body... Casey
Old 03-21-2016, 11:48 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Hmmm, we've got the regular non-truck version of the same intake on another car, and I don't recall ever seeing anything similar....now I wanna do stare at it and see if it actually does
Old 03-22-2016, 01:21 AM   #5
izzy_Britton
izzy_Britton's Avatar
Video please
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 03-22-2016, 11:28 AM   #6
tucker69
tucker69's Avatar
Originally Posted by izzy_Britton View Post
Video please
You are asking a lot from a tech challenged ole guy. "Fast" asked for the same thing, I didn't have much luck...will try.. Casey
Old 03-22-2016, 09:47 AM   #7
Shon
that should not be happening.
Is it a New intake or a used one? if new, I would be calling Comp/FAST to figure out if they may some idea of what's happening, ie bad batch!?
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 03-23-2016, 12:34 PM   #8
tucker69
tucker69's Avatar
Old 03-23-2016, 05:57 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Check that your upper and lower shell pieces are fully seated and bolted together. The upper shell has the TB, and can move on its gasket.
Old 03-24-2016, 07:54 AM   #10
homemade87
Funny you are having this problem . When I was looking for a performance intake my tuner said stay away from the lsxrt truck intake . Said they flex to much and also is a tuners nightmare . That flex messes with the tune trying to nail down the little quirks . Apparently he has seen a few with the same problem . The intake is so large they just did not build enough support into it . Unless Fast did something to correct this problem it is just the nature of the beast .
homemade87 is offline   Reply With Quote
Old 03-30-2016, 11:46 AM   #11
tucker69
tucker69's Avatar
Got to love hotrodding.... $1000 intake that dances to the beat... why isn't that in the sales brochure?
Old 03-30-2016, 12:32 PM   #12
akdg87
akdg87's Avatar
this is a fairly good read on ls intakes: http://www.hotrod.com/features/1507-...ifolds-tested/
granted the factory intakes don't quite look as good as the aftermarket..
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 10-04-2020, 08:31 PM   #13
Robznob11
Robznob11's Avatar
So this is the only thread i can find on this but yea im freeked out to. Just put one on my truck and it does exactly what is stated above. I put a huge filter on and it lessened it some but definitely dances. Any update after 4 years?
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
