08-25-2016, 07:36 PM | #1 |
6.5" van rally's
I have a 69 gmc and need to know if 6.5" van rally's will fit in front if using 2 1/2" drop spindles? Thought i remember hearing there was possible issues with this. thanks
08-25-2016, 07:52 PM | #2 |
Fabricate till you "puke"
Re: 6.5" van rally's
If you have an issue, it will likely be a matter of trimming the outer edge of the lower A-arm or clearance.....longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
08-25-2016, 07:53 PM | #3 |
67-72 parts collector,…
Edit:crazy longhorn types faster than me. Ha
They have a 4" backspace just like the 15x8 rally wheels. You might have to trim the lower a-arm on both sides of the lower balljoint. No big deal. 10 minutes per side with a grinder and a cut-off wheel.
08-25-2016, 08:19 PM | #4 |
We are on the same page brother.....but I don't type that fast!
08-25-2016, 08:19 PM | #5 |
would any modifications be required if i find 15 x 7 rally's and use those instead?
08-25-2016, 08:22 PM | #6 |
08-25-2016, 08:20 PM | #7 |
i have 6.5" van rallies mounted on Early Classic Ent. 2 1/2" drop spindles and it's also on air bags with NO rubbing issues and NO trimming.
08-25-2016, 08:45 PM | #8 |
15x7's have a 3-5/8" backspace.
I still trim the a-arms so all wheels will fit. Depending on how bulky the spindle castings are, some people even have to clearance the outer tie rod arm of the spindle..
08-26-2016, 08:06 PM | #9 |
guess ill have to do that then if they rub. thanks
