01-18-2017, 03:30 AM | #1 |
1954 Chevy 3600 Truck - 8 lug wheels hubcaps?
Hello from Istanbul,
I have 1954 Chevy 3600 truck. I want white wall new tires.My wheels are 8 lug and aliminium.I want to use steel new wheels and hubcaps with new tires.What is your suggestion? I saw bottom wheels.Are they fit my truck? It is 16 inch.And which hubcaps can I use with new steel 8 lug wheels? Thank you very much for your answers. Serkan Okay |
01-18-2017, 09:48 AM | #2 |
Re: 1954 Chevy 3600 Truck - 8 lug wheels hubcaps?
The 8 lug steel wheel in question will work. Dexstar trailer wheels work good, Wheel Vintiques has them too. Also, Ford E250/E350 van rims work good also. Make sure you have 4.25" or LESS backspacing or you're dead in the water. You won't clear the tie rod.
You'll have to install hubcap clips. Most vendors have them. Here's how. http://www.laroke.com/larryk4674/smo...er/hubcaps.htm THe 54/55 trucks use a Bowtie hubcap. I've NEVER seen an aftermarket replacement for them. All that is availible is the script type that the 53 and earlier trucks use. My 54 had Hubcaps on it, luckily. I bought a parts truck and was able to get 2 more. I'm treating them like gold bars. http://www.classicparts.com/1947-53-...ctinfo/64-020/ |
01-18-2017, 11:11 AM | #3 |
These will work as they are 3.5 backspacing.
Am i right whitedog?? and you can put the hubcap clips on your self http://www.etrailer.com/Tires-and-Wh...r/AM20766.html |
01-18-2017, 12:34 PM | #4 |
Here's a couple links on the subject
http://www.stovebolt.com/ubbthreads/...1158249/1.html http://www.stovebolt.com/ubbthreads/.../748598/1.html I have Ford rims on mine right now. Everything is good. I know some update to the modern style tie rod end so it's not so close to the tire. I've never tried to mount my hubcaps, but they fit in the center just fine. |
01-18-2017, 12:45 PM | #5 |
There's always a generic Blank hub cap. Which isn't that bad.
Also, the 67-72 Chevy hub caps are kind of cool. |
01-18-2017, 01:18 PM | #6 |
I purchased Stainless moons from HubCapMike. I have a '50 3600. these will cover and clear the rear axle housing. Just need to make a few measurements over the nubs. I went with trim rings as well. edit: wheels are 8 lug fords 16"
http://hubcapmike.com/choose-baby-mo...p-size-wz.html |
01-18-2017, 08:13 PM | #7 |
You are thinking the smaller hubcaps and not full hubcaps?
The wheels that are on the truck now look like the "bling" wheels that many of the local tires stores push.
01-19-2017, 03:27 AM | #8 |
Thanks for all answers..
Hubcapmike suggested this hubcaps for Dexstar 8 lug steel wheels http://www.hubcapmike.com/11-7-8-12-baby-moon.html Yes. I want to use center hubcaps,not full caps. Which web site can I see ford 16' 8 lug steel wheels? cokertire want to choose size for 8 lug wheels. I saw 16x6 16x7 16x8 and 16x10. I dont understand.which one suitable for my truck? My last question : What is the recommendation of tire size for 8 lug wheels? I want thick white wall. Thank you very much. |
01-19-2017, 11:02 AM | #9 |
The 16x6 or 16x7 isgood for your truck. Just make sure you get the right backspace. The Ford works good. The ones I have are right around 4.25 backspace. A little less would be better. I had a rim given to me that was a 4.5 backspace (I believe it was a GM), it absolutely wouldn't fit the front. It is fine on the rear, but not the front.
Here's a good link that shows the Ford Wheels, they price them at $75. http://ricksontruckwheels.com/wheels-oe.php Call this place too, they have new take offs, may be able to hook you up. They used have parts inventory online, but not anymore. http://www.famvans.com/ Here's s Ford wheel on the front of my 54. |
01-19-2017, 11:06 AM | #10 |
Here's 2007- 2010 Ford rim. I think it looks more like the OEM. It doesn't have the hubcap nubs, but would be good for a hubcap mounted with clips.
I've always thought they would be cool with no hubcap, just chrome lugnuts and chrome bolt covers on the rear hub. |
01-19-2017, 12:27 PM | #11 |
For white wall tires you will probably need to go with 15 inch or 16 inch wheels to be able to buy the available white walls that will fit the truck.
Here is a link to a 16 x 6.5 8 lug wheel. http://www.wheelsandcaps.com/p-23674...6x65-8009.aspx That company has several plain steel 8 lug offerings but they are reconditioned used wheels. It might help your search for the wheels you want to look for though as their photos are good. main web page link here. http://www.wheelsandcaps.com/c-2285-...aspx?pagenum=2 Guys remember, 1954Chevy3600 is in Istanbul Turkey so shipping and logistics are going to be a challenge for him.
01-19-2017, 12:53 PM | #12 |
Coker shows new 8 lug 16 inch wheels powdercoated black for 115 US
https://www.cokertire.com/8-lug-wheel-primed.html This is just for an example. 8 lug 16 inch 1970 Chevrolet C20 wheel https://seattle.craigslist.org/tac/wto/5960047315.html Ford 16 inch wheels. I use a Ford 8 lug rim as a spare on my 3/4 ton GMC. again just as an example https://portland.craigslist.org/wsc/wto/5956927334.html Wide whitewalls are going to be even more expensive for 16 inch wheels than for 15 inch wheels though.
01-19-2017, 06:15 PM | #13 |
Just for info: classicparts has the correct 54 hub caps but only for 1/2 ton 3100 trucks. http://www.classicparts.com/mobile/1.../#.WIE53IE8KaM
1949/1954 with LS swap-yeah! http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos |
01-20-2017, 08:26 AM | #14 |
1954 Chevy 3600 Truck 700-16 Tires?
I want to buy steel 8 lug wheels and white wall tires from Cokertire.com.
We talked this wheels you know. https://www.cokertire.com/8-lug-wheel-primed-16x6.html 700 - 16 Goodrich Tires fit to this wheel? How does it look to you? What is the new measure 700 - 16 ? Does anyone have 700-16? Thanks for all answers. |
03-12-2017, 06:35 PM | #15 |
This is the correct hubcap for a 3600 series truck not mine (they are expensive not repopped) http://www.ebay.com/itm/NOS-1954-Che...BYK21t&vxp=mtr. Will not mount to newer bump type wheels, you'll will need clips. Whitdog76 posted a link to the clip installation to modern wheel page. IMO, blackwalls look better on 3/4 ton trucks. Just add silver ring to outer edge of a gloss black wheel to simulate the old school lock ring.
Tags |
8 lug wheel, hubcaps |
