05-15-2017, 07:21 PM | #1 |
Trying to identify gmc suburban
I got this old gmc suburban. I want to know what kind it is. All I know is that it is a 4 wheel drive. There are some numbers in the glove compartment. Does anyone know where I can go to find out what these numbers mean?
05-15-2017, 10:01 PM | #2 |
Re: Trying to identify gmc suburban
If you try a little harder, you could be more vague. How about a year, picture, the numbers themselves. The first suburban was in the 1930s something
05-16-2017, 02:55 PM | #3 |
Look at a "vin decoder" for suburban
05-17-2017, 05:56 AM | #4 |
Looks like something in the 1980's. The guy from the junk yard I got it from thought it was a 1987 gmc suburban. Service Parts Identification#638249 Order#9KR808
05-17-2017, 06:12 AM | #5 |
The VIN#1GKEV16K8HF516402
05-17-2017, 07:29 AM | #6 |
Now you've given us something to work with:
1GKEV16K8HF516402 1 = US manufacturer G = GM K = GMC nameplate, "multipurpose" vehicle E=brake system V= 4wd (formerly "K") 1 = 1/2 ton 6 = Suburban K=5.7L V8 8=randomized check digit H = 1987 model year F = Flint Assembly (Line 1 = pickup; Line 2 = Blazer/Suburban) 516402 = sequential portion of VIN So: it's a '87 1/2 ton 4wd GMC Suburban with a 350 cubic inch small block Chevy engine, built in Flint, Michigan. We can either tell for certain or guess pretty much everything about that truck except the colors based on that. https://www.gmheritagecenter.com/doc...t-Suburban.pdf The label in the glove box is called the "SPID" ("Service Parts ID") label. The codes that populate the label are the "RPO" (Regular Production Option) codes, consisting of the optional content on the vehicle so that you can get the correct parts. You can get more information on them from the link I posted above, or find an "RPO decoder" and type them in individually. The order number is referencing the original order placed by the dealer to get the truck built. The truck is tracked by the order number until it is assigned to the final assembly location and is the truck's "name" until the plant identifiers (PVI and general assembly sequence numbers) are established. It doesn't mean anything to anyone anymore. Once the vehicle leaves the plant the VIN takes precedence. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 05-18-2017 at 02:02 PM. |
05-19-2017, 12:39 AM | #7 |
Thanks for the help Keith Seymore. I really appreciate it.
Tags |
1987, gmc, suburban 4x4 |
