03-13-2018, 10:59 PM | #1 |
69 c10 ls/th350
What are guys using to "T" off at LS truck intake to use for brake booster and th350 modulator vacuum?
03-13-2018, 11:10 PM | #2 |
Re: 69 c10 ls/th350
There is a nipple on the back of the manifold , or 2 , I think you have to pop off the end of it if the donor truck had hydraboost
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
03-14-2018, 12:15 AM | #3 |
Re: 69 c10 ls/th350
Not sure if donor had hydro or not. It does have an opening for booster I think...measures 7/8". Been trying to find a T fitting ...no luck yet.
03-14-2018, 12:26 AM | #4 |
Re: 69 c10 ls/th350
My 6.0 LQ4 donor did not have a booster as it had hydro boost. However the vacuum was on the back of the manifold but it had a plug in it. Pulled out the plug and used a vacuum hose off a 1500 truck that had a vacuum booster.
As far as the TH350 modulator, I connected to a nipple on the manifold on the passenger side. It was capped as well but I just cut off the cap. transmission shifts as it should.
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 2014 Ram 4x4 3500 Laramie Diesel..Momma's truck 2015 Ram 4x4 1500 1997 Boxster. 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped |
