![]() Join Date: Oct 2017
Power steering lines...help
Running a stock 69 steering box, 5.3 engine and pump. I have fitting adapter for pump...anyone have a link for what hoses guys are using?
Re: Power steering lines...help
Just use the factory 69 hoses.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Fitting on hose is angled opposite direction...just wanted to get new lines...at least the pressure one.
What hose? If you take the fitting out of the pump and replace it with your original one, then the lines will bolt up like stock. The pump should be in just about the same location it was originally.
Junior Member
![]() Join Date: Dec 2017
Take both of your hoses to a hydraulic shop. They can cut off both ends and braze them to swivel crimp fittings. Most will require you to use a new hose. It seems there may be two different style of pumps? I've heard multiple people say to unscrew the fitting on the pressure side. Mine was not removable. It was out of a 2001. My routing did change to under and out the front of the pump. I ended up with the stock ls hard line coming out the front of the pump to a swivel crimp, new hose to the original steering box side the pics help.
#6 | |
![]() Join Date: Sep 2005
i just swaped the fitting in the back of my pump so i could use the stock 1971 line that way i can always gett a replacement if im away from home
