![]() Join Date: Mar 2014
Paint Divider Template
Does anyone have a paint divider template for the 67-72 trucks? I recently picked up the paint divider trim from a part out truck in great shape. Need to drill the holes for the trim clips now, but is there a template out there I can use?
This is the divider that goes on the back of the cab at the bottom of the drop rail from driver to passenger side.
"Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 |
Re: Paint Divider Template
Here's what I have:
Measured on a 72 C20 paint divider trim on back of cab: chrome trim is centered 1&5/8" above body line on back of cab bottom of chrome trim lines up with the color split on the door, NOT the bottom of the drip rail Measured from the edge of the door jamb, NOT the inside of the drip rail: #1 rivet 1&1/4" from jamb #2 rivet 5&1/4" from jamb (3&7/8" from #1) #3 rivet centered between 10&3/4" and 10&7/8" from #2 ( 5&1/2" from #2) #4 rivet 18&1/4" from jamb (7&1/2 from #3) #5 rivet 9&1/2" from #4 #6 rivet 9&1/2" from #5 (this is the center of cab, repeat on other side) From a forum member (GM assembly guide) Sorry, don't know who. measuring from the center line of the rear of cab: 2.16" down from window lip (very top with glass out?) 1st rivet 1.5" from CL 2nd rivet 9.5 from CL 3rd rivet 19" from CL 4th rivet 28.5" from CL 5th rivet (on cab corner) 0.93" foreward from rear of cab 6th rivet (one closest to door) 4.5" from rear of cab |
#3 | |
SWEET man thank you so much!!!
Tags |
67-72, paint divider, template, trucks |
