06-13-2018, 12:25 PM | #1 |
Center Bore Diameter
I have a -70 shortbed stepside. Disk brakes in front. Drums rear.
Question 1: the wheels is lug centric (not hub centric)? Question 2: does it matter how wide the center bore diameter on the rim is, given yes on question1, and have this Lug Nut Seat Style Conical seat - 60 degree? Do not know what it is on mine, but let us say it is 78,3 mm. Will rims with 108 mm center bore diameter fit? |
06-13-2018, 12:48 PM | #2 |
Re: Center Bore Diameter
The original wheels are hub centric, but you can use lug centric on your truck. Most aftermarket wheels are lug centric so they fit more applications.
Yes, a larger bore lug centric wheel will fit (backspacing is a different matter). Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
06-15-2018, 08:08 AM | #3 |
Is your truck 6 lug disc or 5? If someone has converted the truck to 5 lug then both ends probably have the same pilot diameter for the wheel hub and you could get hubcentric wheels.
But if you are 6 lug still, the rear pilot will be significantly larger diameter than the front.
06-15-2018, 09:36 AM | #4 | |
Tags |
hub size, wheels |
