07-11-2018, 04:33 PM | #1 |
5.3 knock/cam sensor not connected
I had done one of this swaps about 10 yea4s ago, however I recently bought a truck that swap was done by someone else.while it seems like they put some quality stuff as headers, trans controller, hid the wires etc etc , i removed the intake today and i notice the sensor on the rear of the engine is not connected nor it was connected ever since there is no wire connector going to it. The truck runs very good and strong but how is this possible? The harness is not hooked up to a oem ecm. Instead it has a aftermarket engine module, but I thought the sensor was needed for the engine to actually run. Any ideas
2017 king ranch power stroke 57 chevy big rear window, camaro front clip, rear is notched 57 chevy truck, air ride, ls swapped. 52 chevy truck waiting its turn. |
07-11-2018, 10:43 PM | #2 |
meowMEOWmeowMEOW
Re: 5.3 knock/cam sensor not connected
Depends on what you mean by aftermarket engine module. Physically an LS motor can run without any of its sensors, it just wouldn't have fuel or spark control. Things like Megasquirt will run a different cam sensor. Without cam sensor reference it would just fire all the coils simultaneously
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
07-11-2018, 11:26 PM | #3 | |
BMW & ASE Master Certified
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
07-12-2018, 09:14 AM | #4 |
I found out the secret last night, the previous owner or whoever swapped the engine, actually had the sensor re located to the front timing gear/chain cover.
07-12-2018, 11:39 PM | #5 |
That’s the valve lifter oil manifold connector it is what is used to activate the dod lifters. I assume they tuned it not to use them and just didn’t swap the covers out. Maybe it still has all the active lifters in the engine
07-14-2018, 10:08 AM | #6 |
I see. I have only done one of this ls swaps and it was 10 years ago, the trucks runs very strong no issues, so i wasnt very worry about it , thanks for the help
