67-72 blazer fuel tank electric fuel pump
Has anyone put an electric fuel pump in a 67-72 k5 tank ? I have found later 87 tank info but nothing on 67-72 tanks. I already have fuel tank mounted.
P.S.- I am running a 5.3 |
Re: 67-72 blazer fuel tank electric fuel pump
Bumping as I am interested in answers. On a new tank it probably wouldn’t be too difficult to weld in a later model pump bung/receptacle (what is it really called) so an easily obtained GM pump assembly can be used?
Tanks inc has a couple of solutions also. https://www.tanksinc.com/index.cfm/p...=cat/cat61.htm
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
![]() I had a shop weld in a tray to mount mine, seems the most problem I had was the locking ring to keep it in the tank. There is a universal locking system now available thru out the industry
What pump did you use?
![]() It's more the mounting bracket then the pump, but my pump puts out 55psi
![]() the ss gets welded to the tray, and the black locking ring is installed on top of it. While you're in there, I would change the neck on the tank
