#8 coil touching firewall
5.3 installed in my 66. Everything fitting great, went to install coils on right side and #8 coil is tight to firewall. Can't bolt up or get wire on. Anyone else run into this issue? Looking for a fix,don't want to adjust firewall. Drivers side fits perfect.
Re: #8 coil touching firewall
Are your motor mount adapter plates adjustable? Mine had 4 positions and I had to use the 3rd position away from the firewall to clear the passenger side coil. I still had to remove the last mounting stud. Mine is a Gen IV 5.3.
Just got to make the motor go forward. I had this and pretty much did what bigmoe did.
Or you can buy some custom coil brackets. |
![]() Join Date: Feb 2014
I don’t have a picture of mine right now I had the same problem remove the last mounting stud but still didn’t have quite enough room so I shortened the bracket between 7 and 8 I already had the motor mounted and the driveshaft installed
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
Sounds like a good idea with the bracket mod.My perches are in the rear holes. Have DD plates and am in the 4 th hole closest the firewall. Motor is as far forward as I can get it. Wasnt impressed when I seen coil touch. Trans and shifter all bolted up.
Yeah that’s how I felt with the driveshaft and everything all in and ready to go but I intentionally set my motor back as far and as low as possible Not thinking about the coil’s
Roto Reuter thats the name...
![]() Join Date: Feb 2010
I installed a 5.3L LM7 in my '70 K10. Definitely tight to the firewall. I didn't want to slide everything forward because it would've affected front and rear driveshafts (besides being a PITA). First I removed the rear mounting coil stud. Then I decided to change my coil brackets totally. Went with ICT Billet coil mounts. Not that it made a big difference, but I think it helped some.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
#8 | |
![]() Join Date: Jul 2009
