04-22-2020, 01:10 PM | #1 |
*New Door Panels Not Fitting*
I'm back on my door panels since I have a lot of time on my hands due to the Covid-19 pandemic. I bought some 1/8" Hardboard Tempered Panel at Home Depot and got one panel cut. I drilled the holes a little over-sized so the panel would float a little to line it up. Ran into a problem. The panel is hitting the door remote at the handle and the rod causing the panel to buckle a little at the top right and making the door handle not work very well. The spring now will not return the door handle back to it's default position. I checked the thickness of the original black board panel with calipers and it is 5/64". Not much difference in the 1/8" thick panel I have. I tried adding 1/8" washers behind the panel but still to tight. How did you guys remedy this issue when making your own door panels???
If you can't fix it with duct tape, it's an electrical problem. 1949 5 Window 3100 https://zippi6.wixsite.com/adtruck Last edited by Zippi; 04-22-2020 at 02:09 PM. |
04-22-2020, 03:14 PM | #2 |
Re: *New Door Panels Not Fitting*
I can think of 2 options.
1: Use a thinner more flexible material, like kydex or aluminum. I made mine out of .032 aluminum. 2: Modify the regulator so the bar sits n the channel. It can be done, I just don't remember the process. I'm sure some others may have a better idea.
1951 Truck, LS1/4L60 1964 Suburban, current project 2014 Silverado daily driver 1953 Westerner "canned ham" trailer, rebuilt 1974 Prowler trailer, rebuilt |
04-22-2020, 03:24 PM | #3 | |
If you can't fix it with duct tape, it's an electrical problem. 1949 5 Window 3100 https://zippi6.wixsite.com/adtruck |
04-22-2020, 04:09 PM | #4 |
The easy way to modify the regulator and arm is to swap sides with the door latch regulator. Then flip it so the rod will sit in the channel like it is supposed to. You will need to shorten the arm. Just cut and reweld it to fit.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors '72 3/4 Cheyenne Super 350/200R4 '50 1/2 Chevy 3 Window |
04-22-2020, 04:26 PM | #5 |
When Chevy reversed the door handle rotation direction (49?), they just let the remotes rub. That works okay for those flexible factory panels, but not for the stiffer panels you are using.
Get some 47-48 remotes that run horizontally in the recess, or modify some '65 C10 remotes like I did below.
1951 Chevy Panel Truck Last edited by MiraclePieCo; 04-22-2020 at 04:32 PM. |
04-22-2020, 05:44 PM | #6 |
Thanks for the replays. I just modified both remotes a few months ago and got them working great. Don't have a welder. Can the remote be turned upside down so the bar fits in the channel? I think I have them shimmed out and working pretty good. It passed my 3 point inspection process......the wife, the wife, the wife.
04-22-2020, 11:15 PM | #7 |
I would try something different. Take your current panel and cut it to clear all the mechanical parts, so it fit flat on door. Now make another panel same size as first panel and glue together. Your panel will be about a 1/4" thick but should lay flat.
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
04-23-2020, 07:49 AM | #8 |
I appreciated the idea. That is something to keep in mind. Not sure if my window and door handle would fit using 1/4" panels but something thinner could be used. There is always more than one way to skin a cat ☺
04-23-2020, 01:28 PM | #9 |
oldman3,
That was a great idea. I cut a clearance slot for the remote bar to operate. With all screws tightened up (no washers added behind the panel) and the arm rest in place it operates smoothly. The round head where the bar fastens onto the remote is flush with the panel. I don't think I'll need to add anything on top of the panel as once the 1/2" pad and leather are secured to the panel I don't think you'll even notice anything. I'm a Happy Camper ☺
04-23-2020, 03:11 PM | #10 |
jim (oldman) has done this a couple times, his input is great! he has a door panel how-to somewhere on the site
04-23-2020, 04:58 PM | #11 |
sharing your experience and knowledge is what this is all about, great to see, and nice fix.
nice looking truck also
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
04-23-2020, 05:12 PM | #12 |
Thanks for the comment on my 49. Yup.... this site is great. Sometimes others help me with fixes and sometimes I work it out myself. Glad this is working out as I was not wanted to buy 47 or 48 remotes and starting over again. Can't wait to see how the panels come out. My wife thinks her sewing machine will double stitch the leather in white as the seats are. We'll see. Not sure when I will get around to covering them. I bought some 1/4" staples for my Arrow stapler but they were to wide. Dang the bad luck ☺
04-23-2020, 11:38 PM | #13 |
Glad it worked out for you, nice job...Jim
04-24-2020, 07:14 AM | #15 |
04-24-2020, 07:55 PM | #16 |
Great looking door panels. Are the seats from a nova?
04-24-2020, 08:24 PM | #17 |
Seats are out of a 2012 Ford Focus Platinum. Full leather.
04-27-2020, 08:12 AM | #18 |
I have my Ford Charcoal material ordered but it's taking it's time coming from CA. Don't like gluing the material on the door panels so I bought some 1/4" staples. I wanted to use 1/8" staples but can't be found locally. The 1/4" staples go through the panel so I'll have to figure something out there. Maybe add a shim. I wanted to use 1/4" foam but can't find anything but 1/2" locally. These door panels are fighting me the whole way. I'm hoping the material I ordered is the same color that was pictured.
