Old 06-27-2020, 11:09 AM   #1
BlueJeep
BlueJeep's Avatar
86 Suburban daily driver
I picked this up May, had kinda been looking but not too serious. It had the right look, and the right attributes so I brought it home with me. I grew up riding around in the back of these things, so I guess I'm re-living those memories!
86 Suburban, came from Oklahoma and I haven't been able to find any real rust on it yet (those in the upper midwest and rust belt will know exactly what I mean by this). Had a lot of good things already done to it, and my plan is to refine it and then drive it everyday. We'll see how that evolves with time. Main needs are to be reliable and comfortable for the whole family.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 06-27-2020, 11:21 AM   #2
BlueJeep
BlueJeep's Avatar
Re: 86 Suburban daily driver
It has some good things going for it, and it also has some needs after 34 years.
Here's what I've been able to ascertain it has had done to it:
- 4/6 drop.
- McGaughys spindles and MaxTrac springs
- Flip in rear (no notch)
- At some point it had a remanufactured 350
- Weiand Street Warrior intake
- Holley 4160 carb
- Ceramic coated headers and some dress up stuff.
- Jeep steering shaft
- Boss 338 wheels, 18x8 and 20x10, 255/45r18 in the front and 295/45r20 in the rear
- drilled and slotted rotors on the front
- phantom billet grille....not sure what to think of this yet
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 06-27-2020, 11:30 AM   #3
BlueJeep
BlueJeep's Avatar
First order of business will be to check things out and start fixing stuff. I re-packed the front wheel bearings, replaced the rear wheel bearings, and drained the rear diff oil. I noticed a spider gear that had more run through it than just 80-90, so that needed attention. I evaluated the cost of new spider gears, and ultimately decided to replace it with a Quick Performance posi. I also did all the bearings in the diff and put in a crush sleeve eliminator. The driveshaft had bad u-joints, so those were replaced too.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 06-27-2020, 11:37 AM   #4
BlueJeep
BlueJeep's Avatar
The front suspension still needs work. Someone bashed the driver's side lower control arm pretty hard and the bushing is mostly popped out, so I bought a replacement control arm and I'm getting that ready to go now.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 06-27-2020, 01:13 PM   #5
BlueJeep
BlueJeep's Avatar
The rear suspension is where I need to focus on in the very near future. It has a flip, but no notch so the axle SLAMS the frame on a very frequent basis, and this won't do. The picture below shows 1.75" of clearance, but when it is down on the ground with all the weight on it is more like 2 fingers clearance. I haven't been able to find any commercially available notches, which is fine, so I'll build one and weld it in. At the same time I'll be removing the flip brackets and welding on new spring perches and centering the tire in the rear wheel well like it should be. There are air shocks that do not function, and looks like one of the mounts on the frame has been ripped off the frame and cobbled back on. Extended shock mounts will also be fabbed up and I'll run some normal shocks of a decent length.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 07-02-2020, 06:38 PM   #6
SCOTI
SCOTI's Avatar
One 'watch-out'…. Burbs/Blazers are known for issues when c-notching. If you notch it, I would verify there's the same amount of travel available above the different as well. Otherwise, you'll clear @ the axle tube but still hit @ the floor.
Cool family ride for the record!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-28-2020, 12:02 AM   #7
ShortHaul
ShortHaul's Avatar
Rad Burb! Where'd you source the control arm?
"Sweet Pea" 1975 Cheyenne 20
http://67-72chevytrucks.com/vboard/s...00#post8477900
"Bourbon" 1975 Suburban ScottsdaleSOLD
https://67-72chevytrucks.com/vboard/...49#post8769049
”Otis” 1970 C10 SWB -SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=762766
”Chebby” 1962 Impala LS/TKO-500
http://www.pro-touring.com/threads/1...2-Impala-Build
ShortHaul is offline   Reply With Quote
Old 06-28-2020, 07:50 AM   #8
BlueJeep
BlueJeep's Avatar
Thanks!
Control arm was used off Ebay.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 06-28-2020, 08:09 AM   #9
BlueJeep
BlueJeep's Avatar
So as could probably be expected, nothing worked. Power locks didn't work, and the front 2 windows would eventually go down, but the rear ones wouldn't. Some time with a multi-meter let me to conclude that power was getting where it should, but switches were bad. I replaced both power lock switches and one of the solenoids, and did some lube-ing and now all 5 doors lock and unlock reliably with the switches. Windows were a similar treatment, only the driver's door window switch worked so the rest were replaced and I'm waiting on 2 window motors and then all the windows should work too. I still plan on putting relays in the doors for the windows to work quicker, but haven't gotten to that yet. All the rubber and glass runs also will need to be replaced too.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 06-28-2020, 09:04 PM   #10
BlueJeep
BlueJeep's Avatar
Today I was able to tackle the oil cooler....and get rid of it. It leaked just like they all do and it felt good to get rid of that particular leak and clean up the bottom of the engine just a bit.
Since I had the grille out I took that opportunity to install the temperature sensor for my compass/temperature rearview mirror. I add these mirrors to all of my projects, love 'em!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 06-28-2020, 10:56 PM   #11
blakeduren
Has that vehicle always been a 1/2 ton? I didn’t know that the half tons got an engine oil cooler on the 350.
I just redid the oil cooler lines on my 83 454 Burban.
I enjoy the build thread!
blakeduren is offline   Reply With Quote
Old 06-30-2020, 03:42 PM   #12
Nice looking burb project.
Old 06-30-2020, 09:02 PM   #13
LT7A
Dude, that sucks with the glass. My whole thing with these trucks is that since somebody else wore it out, I'm trying to wear it back in – so to speak. I get so frustrated when my efforts produce damage. My best idea is for you to watch Craigslist, Facebook Marketplace, maybe even Offer-up. There always seem to be a few Suburbans being parted out.
Old 07-02-2020, 09:28 AM   #14
Rich84
Rich84's Avatar
Cool project..You are getting busy.
Rich84 is offline   Reply With Quote
Old 07-13-2020, 10:59 PM   #15
focusedontheprize
focusedontheprize's Avatar
Nice fix and great thread on the truck. The wiring on these trucks are always funny, the last two trucks I had have given me heart palpitations when I started working on them.
focusedontheprize is offline   Reply With Quote
Old 07-16-2020, 06:41 AM   #16
Hart_Rod
Hart_Rod's Avatar
Looks like a fun project,
Hart_Rod is offline   Reply With Quote
Old 07-21-2020, 02:30 PM   #17
SBTork
Garage wrench
SBTork's Avatar
Awesome build! Reminds me of mine for sure.
Would you happen to have a picture or could take one of the rear barn door lock actuator location/bracket/etc? I need to add one to my '85 as it never had one and I'd really like to add it.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 07-21-2020, 03:51 PM   #18
BlueJeep
BlueJeep's Avatar
Thanks all! LED headlight upgrade is coming next when I get a little time. Found some with great reviews with Amazon open-box pricing! If they work well, it didn't cost much more than the relay harness would have.
Adam, sent you a PM. I can get you any pics/measurements you need.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 07-22-2020, 11:38 AM   #19
ShortHaul
ShortHaul's Avatar
Mind sharing that Amazon link? I’ve been after a set of led headlights for a while, but I’ve found they are either too expensive for my taste, or they look too modern for my taste. I really like the OG looking patterned glass lens that Dapper Lighting offers, but their prices are craaaaazy high.. I also considered VintageCarLED but didn’t find many reviews on their product...
Old 07-22-2020, 12:23 PM   #20
BlueJeep
BlueJeep's Avatar
Sure. These are pretty modern looking, but because of the phantom grille on my sub I don't think it will be noticeable.
Here is the review (which I found very informative):
https://www.youtube.com/watch?v=wDJrn0JD_wM&t=1s
And the Amazon link to what I bought (4x6 rectangle, I know yours are round). I took advantage of the "used" option on Amazon for mine, which are usually their returns that the original packaging is damaged but the product itself isn't, and they sell at discounted prices. I paid $65.xx for these.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 07-22-2020, 11:10 PM   #21
BlueJeep
BlueJeep's Avatar
Had some craigslist luck today and scored a 2wd 4L60e, which aren't super easy to find here! Also found some Trailblazer SS exhaust manifolds last weekend. Collecting parts.....
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 07-23-2020, 09:47 AM   #22
Pontiac1976
Pontiac1976's Avatar
I hope you checked the manifolds good because they prone to cracks. They look like they been running a little hot the on the right mostly. The cracks mostly happen at the v off the ports. Just in case you did not know good luck.
looking pretty good so far for the burb.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 07-23-2020, 10:20 AM   #23
BlueJeep
BlueJeep's Avatar
Thanks for the tip, I did not know that so I'll have to check them out good.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 08-23-2020, 09:19 PM   #24
BlueJeep
BlueJeep's Avatar
I gave the manifolds a quick dusting in the blast cabinet so I could check for cracks, these are good to go! Were rusty, but other than that just fine.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 09-02-2020, 08:48 AM   #25
focusedontheprize
Nice work and that notch looks to be absolutely solid.
