08-03-2020, 10:41 PM | #1 |
Nu-Relics window crank switch
I just picked up a set of the Nu-Relics window crank switch for the power window. Anyone install these yet? Looking for advice before I jump in. Not sure if they go inside the door or cut to make room on the inner door skin.
Current project: 59 Apache with 2012 Corvette drivetrain Jeep Trackhawk(beast) |
08-04-2020, 12:33 PM | #2 |
Re: Nu-Relics window crank switch
they are intended to replace your crank mechanism on the inside of the door skin, hence the splined shaft for your window handle. if they dont lineup with the original mechanism mounting screw holes, stick it thru the handle hole in the inner door panel and locate new ones. Nu relics makes great stuff, i use in my streetrods. good luck!!!
