Old 12-05-2020, 01:51 AM   #1
Greasey Harley
Greasey Harley's Avatar
mount square body sway bar on '68 C10
Today I salvaged the sway bar off a square body C20.
I plan on using it on my '68 C10. I ordered the bushings and a pair of mounts for a lowered truck.
I don't have all the parts yet, and my front end is currently ripped apart.
It doesn't look like the '68 has mounting holes in the frame for the sway bar brackets.
Is there a measurement for these, or do I just "kinda eyeball it"?
Perhaps it will be self explanatory when everything is together?
Junk yard pickin' pics:
Insert clever text here:
Greasey Harley is offline   Reply With Quote
Old 12-05-2020, 12:40 PM   #2
MySons68C20
MySons68C20's Avatar
Re: mount square body sway bar on '68 C10
I'll take a pic along with dimensions of my C20 if someone doesn't beat me to it.
MySons68C20 is offline   Reply With Quote
Old 12-05-2020, 06:15 PM   #3
MySons68C20
Didn't get a pic but I am at 9" from the longest part of the front on frame to the 1st bracket mounting hole where it is riveted through the frame.
Looks to me like you can mount the bar to the a-arms and center the bracket wherever it hits the frame.
Old 12-06-2020, 08:33 PM   #4
SkidmoreGarage
The replies here pretty much have it, but you should have rivets in the stock locations. When you bolt it up, you should see what needs to happen.
The rear rivet is located by the intersection of the front frame cross member and the frame extension.
SkidmoreGarage is offline   Reply With Quote
Old 12-07-2020, 11:35 AM   #5
SCOTI
SCOTI's Avatar
Install the end bushings on the bar @ the a-arms & snug the hardware. Lift the bar until the frame bushings contact the frame & you'll see exactly where it needs to be mounted.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-07-2020, 11:01 PM   #6
Greasey Harley
So it sounds like it's just kind of self explanatory when I get it together.
I was just hoping to mount the bracket while it's up on the lift.
Thanks for the replies.
-Russ
Old 12-08-2020, 07:56 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The empty hole there on the framerail and the one with the rivet in it. That's the ones you need.
I did this article 16 years ago. It should walk you through any aspects of the job that you're hazy on.
http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-08-2020, 08:08 PM   #8
SCOTI
SCOTI's Avatar
WHAAAAAAAAAAAAAAAAAAAAAT the heck!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-08-2020, 09:57 PM   #9
Greasey Harley
Yup, that's where I got the idea. Great article. Thanks for taking the to post it.
-Russ
Guess I skipped over that part
Old 12-09-2020, 06:03 PM   #10
MySons68C20
Missed seeing you on here Texas!
Old 04-17-2021, 10:30 PM   #11
Greasey Harley
I'm not very good, but I sure am slow.
Finally got the sway bar installed today.
This in addition to the rebuilt front end, all 4 springs and shocks, 3.5/5 drop and disc brakes, etc., etc...
WOW!! The old truck drives great!
Name:  Junk Yard C20 Square Body Sway Bar on 1968 C10.jpg
Old 04-18-2021, 03:34 PM   #12
MySons68C20
Thumbs up Re: mount square body sway bar on '68 C10
Congrats!! Amazing what a difference it makes.
