04-01-2021, 11:00 PM | #1 |
89 C30 Crew Cab - Gen V LT1/8L90e Install Questions
I have an 89 C30 Crew Cab that is currently under the knife to have a PB Fab Front and Rear bagged suspension installed so I can look at my 22” Alcoas and clean the top of the hood easier.
I am looking at repowering my C30 CC with a 2016 (+/-) Gen V LT1/8L90e combo and have some questions. I will probably source the engine through a supplier that strips cars and pallets up the entire engine/tranny/ECU/pedal and will even swap out the cam to dump the VVTs and tune the ecu to dump the AFM, I used them on a previous L99/6L80e swap into an old (65) Caddy. The PB Fab front kit uses a Rack n Pinion steering setup but the Gen V LT1s don’t have a PS pump? • Has anyone any experience with the aftermarket solutions in a Squarebody? I have seen Dirty Dingo’s solution and All American Billet looks to have a bracket and pully • What are the physical dimensions of the 8L90e – I am assuming that I will need to tunnel the truck, which isn’t that big a deal. Both Holley and Moroso make oil pans so that seems pretty straight forward. I already planned on getting a Dakota Digital dash for the pig, so gauges should be taken care of. • I would like to keep the dual saddle tanks, Can I add a third tank and feed it from the saddle tanks? • Are there any other major or semi-big items that I will need to deal with and plan for?
Sent by the random thoughts from the voices in my head... |
04-02-2021, 04:51 PM | #2 |
Re: 89 C30 Crew Cab - Gen V LT1/8L90e Install Questions
Sounds like a good project.
Just a note in regards to the 8L90E it doesn't get a lot of love on LS1tech.com. Go take look in the auto trans forum for comments. |
04-04-2021, 11:03 PM | #3 |
No one? I can't be the first, I am too old for that.
04-05-2021, 01:35 PM | #4 |
BMW & ASE Master Certified
First for what? search button my friends, 3-4 of us including my self have build threads. Power steering, lools like you found solutions. Fuel systems a fuel system, plan it out amd youll be fine. If your goo wiring, there's a gen5 connector kit on ebay. Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
04-05-2021, 02:26 PM | #5 | |
I have done an L99/680e swap into my 65 Caddy but have no experience with the Gen V LT1. I did see some of your fab work, quite impressive BTW. I was looking for some input from others on their experiences pertaining to the Gen V LT1 swap and anything that they ran into. The Dirty Dingo PS pump setup looks pretty involved vs the All American Billet system uses a KRC Pro Series III Pump but I am not sure which pully or damper it uses. Hooker lists a PS pump bracket for the LT4 but doesn't mention the LT1 and have heard rumors of it being ill-fitting, Eddie Motorsports has one also, then there is the electric Volvo pump....
Sent by the random thoughts from the voices in my head... Last edited by EricU; 04-05-2021 at 02:41 PM. |
04-07-2021, 07:28 PM | #6 |
Power steering brackete are specific as like LS... car vs truck balancer spacing is different.
Lt1 has a double sided belt no? Gonna be hard to find a belt driven solution without scrapping the waterpump and going LS waterpump ,adapter and custom brackets. Clint
04-07-2021, 08:35 PM | #7 |
My biggest problem is that I don't have the motor in front of me yet as it will be a few weeks out.
I did find that the L8T PS bracket GM P/N 12654286 should fit a type 2 PS pump to the LT1. I haven't really worked with a type 2 PS pump before as my LS swap into my old Caddy was pretty straight forward. I need to dig into it to figure out a remote reservoir to work with the factory hydroboost and Unisteer R&P. I "think" that I would need to change to the LS style water pump which doesn't really bother me as they are quite available. I have a hard time swallowing the Holley Mid Mount pricing but I don't really want to spend the time that I did designing/building a serp system for my old Caddy 472 motor....
