04-23-2021, 06:43 PM | #1 |
American Autowire and glove box light
Question for those that have used the American Autowire kit, I’m not finding a spot for the wire. The manual says it’s a 12v battery fused for glove box, but even the lights I’m finding online don’t look like they use this connector.
04-23-2021, 07:08 PM | #2 |
Re: American Autowire and glove box light
Is the glove box circuit a separate option?..when I pulled it up it shows a light and switch for about 20bucks..
I've not seen a connector like that before
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 04-23-2021 at 07:15 PM. |
04-23-2021, 07:24 PM | #3 |
That terminal should fit right inside the glovebox light socket / switch assembly. Goes right up alongside the bulb and one of the little "pins" on the base of the bulb hooks into the notch in the center of that terminal.
04-23-2021, 07:53 PM | #4 |
Moderator
Yes, thats what my glovebox light looks like.
04-23-2021, 09:51 PM | #5 |
I am about to buy a glove box light also...did you guys connect the hot wire to a battery or ignition 12v source?
04-24-2021, 10:54 AM | #6 |
04-24-2021, 03:21 PM | #7 |
What were they originally on anytime the box was open or only when the ignition is on?
04-25-2021, 06:08 AM | #8 |
04-25-2021, 12:24 PM | #9 |
That connector on the american autowire kit will fit into the kits accessory circuit that has several connectors both ignition powered and direct to battery powered. That is what I used.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
