Old 11-02-2021, 04:18 PM   #1
hooverfish
hooverfish's Avatar
BUCKET SEATS in a 1984 ??
I'm wanting to put buckets in my 84 but not sure what I need to buy.
I have set of 75-76 seats from a Blazer (picture below) that I would like to recover use but dont think the blazer brackets are any help.
Been reading old posts on installing buckets but cant find much on 81-87 installations.
I've looked at the brackets sold by Chop Shop.
But need to decide on a slider/seat combination that will fit the 84 floor.
Have seen some references to using bench seat sliders but not sure if my 84 bench sliders can be used.
Are there any bracket or slider combination that will work with my seats and fit a 1984 cab ?
Any help or advice is appreciated.
Larry
84 Chevy SWB, "Roy", dark blue orig paint, 6 cyl auto, PS, 88,000 miles.
72 Highlander LWB "Olive" med olive over lt yellow, air, 77,000 miles (sold)
"It's a sorry man who can't find his wife a good job"
hooverfish is offline   Reply With Quote
Old 11-02-2021, 06:35 PM   #2
TKCR
TKCR's Avatar
Re: BUCKET SEATS in a 1984 ??
The seats you have pictured are actually buckets for the truck. And they take the same track sliders from the 73-76 bench seats. But those are only used on the drivers seat. The passenger seat uses brackets.
Your probably not finding much on the 81-87 installations, because those were actually the high back buckets.
And as far as tracks fitting the cab floor, all the tracks will, from 73-87. It’s whether they bolt up to the bottom of the seat. Certain tracks only bolts directly to it’s corresponding seat frame.
Old 11-03-2021, 04:19 PM   #3
smupser
Active Member
The floors should be the same, Use the seat tracks that fit the seats.
smupser is offline   Reply With Quote
Old 11-03-2021, 06:28 PM   #4
TKCR
TKCR's Avatar
The floors aren’t the same, from the trucks to the Blazers. That’s why the tracks & brackets are different. The tracks I have on my buckets, are just like the truck bench seat tracks.
Old 11-03-2021, 07:53 PM   #5
smupser
Active Member
He was referring to the trucks therefore that’s why I said they are the same 😉
Old 11-04-2021, 10:28 PM   #6
hooverfish
hooverfish's Avatar
First of all, thank, you both for your input !
Actually my seats are from a Blazer, have full plastic backs and passenger side has the flip forward brackets.
Looking at the bolt holes, it doesn't look like the 73-75 bench seat brackets will fit my seats.
My seats only have 4 threaded bolt holes that I can see, the ones in the picture that have the bolts in them.
Or am I missing something ?
Larry
Old 11-17-2021, 06:03 PM   #7
TKCR
TKCR's Avatar
Very nice!
Old 01-09-2022, 09:45 PM   #8
smupser
Active Member
Looked up the listing, says for 81-91. Those consoles are different, did it bolt up to yours?
Old 01-10-2022, 02:58 PM   #9
hooverfish
hooverfish's Avatar
Wow! That’s looking so nice
Thank you Tina
Haven't received it yet, it'll be another 2 or 3 days.
Just thought I can make it work, better than a block of wood, and only $22 shipped so thought I would take a chance.
Do you know where I can buy one like the one you pictured? That's probably what I need.
Larry
Old 01-10-2022, 11:13 PM   #10
smupser
Active Member
Originally Posted by hooverfish View Post
Thank you Tina
The guy I got a couple from is a member here on the forum but I believe he got stationed In Japan so I don’t know if he’s around. I got one from a local guy who specializes in restoring 69-80 consoles, he may have a few laying around.
https://k5blazer-guy.myshopify.com/
Old 01-11-2022, 06:08 PM   #11
hooverfish
hooverfish's Avatar
The guy I got a couple from is a member here on the forum but I believe he got stationed In Japan so I don’t know if he’s around. I got one from a local guy who specializes in restoring 69-80 consoles, he may have a few laying around. ]
Appreciate the info. You and Tina have helped me a lot.
Larry
Old 01-11-2022, 08:19 PM   #12
1rippen6
Just saw you needed the piece to raise the console, do you still need it. I had 2 but will have to locate them.
1rippen6 is offline   Reply With Quote
Old 01-11-2022, 11:23 PM   #13
hooverfish
hooverfish's Avatar
Yes I;m interested, like to see pictures and price. Thanks
Larry
Old 01-11-2022, 11:30 PM   #14
smupser
Active Member
Dwayne will take care of you if he can
Old 01-14-2022, 01:58 PM   #15
HOTFUN
HOTFUN's Avatar
Hooverfish
Just wanted to verify this as my factory 1973 low back seat did not have those extra brackets (blue circled in #9)on rear mount to seat frame on drivers tracks. In picture#9 in blue circle I believe is the later style 75-76 seat brackets and 1973-74 buckets the track was only bolted straight to the seat base. So in picture #14 looks like your seat at the rear also only bolts to the seat frame and those blue circled brackets are not used on yours correct?
Just wanted to check as mine never had any marks that those little angled brackets were ever installed there.
Thanks, Mark
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 01-14-2022, 02:03 PM   #16
HOTFUN
HOTFUN's Avatar
Hooverfish
Thanks, Mark
Sorry I couldn't figure out how to repost you're photos from post 9 and 14 here.
'72 GMC K2500 4x4
Old 01-14-2022, 03:31 PM   #17
hooverfish
hooverfish's Avatar
Hello Mark,
On my seats I used 73-76 bench seat brackets for the Driver side. Had to add two pieces from the Chop-Shop to bolt them in place, circled in blue below.
Also used 4 chop shop brackets on Passenger seat.
Then two C-S brackets that are welded to the floor. Circled in red
Brackets circled in yellow are the two for the Driver seat in pic #1.
And yes, brackets at the rear of the seat bolt directly to the seat.
Hope this answers your question.
Larry
Old 06-27-2022, 11:24 PM   #18
RUN GMC
RUN GMC's Avatar
Hello Mark,
Does the Chop Shop still exist if so could someone post the link to it......the old ebay ones are dead.......
RUN GMC is offline   Reply With Quote
Old 06-27-2022, 11:42 PM   #19
smupser
Active Member
He was on Instagram but I just looked and his profile doesn’t exist anymore. Last I talked to him he said the seat brackets never took off. Sold the last few sets. He said he was still gonna make a hybrid setup to work between the early and Latter style low backs, but no idea when.
Old 06-28-2022, 12:18 AM   #20
RUN GMC
RUN GMC's Avatar
Thanks for the response bro.....I could use them to mount seats in my truck......does he have a facebook page?
Old 01-14-2022, 06:10 PM   #21
HOTFUN
HOTFUN's Avatar
Perfect information. Just what I wanted to know. On the drivers side I had to repair the two oem brackets you have in yellow and I had cutout the original welded brackets from a couple of cash for clunker suburbans back in the day so I am ready to go on my 73 GMC 4x4 shortbox. Thank you very much. Was going to ask you if you sold those 4 nice GMC chrome 10.5" hubcaps you had on here a while back? Thanks Mark
'72 GMC K2500 4x4
Old 01-14-2022, 07:17 PM   #22
hooverfish
hooverfish's Avatar
Were you talking 68 or 72 on the hubcaps ?
Larry
Old 01-14-2022, 07:52 PM   #23
HOTFUN
HOTFUN's Avatar
72 on caps
'72 GMC K2500 4x4
Old 01-14-2022, 11:25 PM   #24
hooverfish
hooverfish's Avatar
No didnt sell them.
Larry
Old 01-17-2022, 08:23 PM   #25
hooverfish
hooverfish's Avatar
Originally Posted by 1rippen6 View Post
Here is what I have, 35 plus shipping, it should fit in a paddled flat rate envelope for 8.
Dwayne, console stand arrived and it fits the 69-75 consoles perfectly.
Thank you
Larry
