Old 11-21-2021, 11:58 AM   #1
parrisc
Can this badge be switched to GMC?
parrisc is offline   Reply With Quote
Old 11-21-2021, 12:24 PM   #2
kipps
Re: Can this badge be switched to GMC?
That looks like a 77-79 grille. The equivalent GMC grilles had a center bar that the "GMC" lettering attached to. There is no center bar on your grille.
Besides that, the whole thing is one molded piece of plastic. You would have to do a lot careful surgery and plastic welding to even remove the Chevy emblem and mount from that grille.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 11-21-2021, 12:31 PM   #3
parrisc
Thanks, yes it is on FB market place as a 78-79 oem grille. I didn't know if those badges were a bolt on. I don't have mine at home to look..
Thanks again.
Old 11-25-2021, 08:32 AM   #4
Big Chip
Big Chip's Avatar
Thanks again.
Are you having trouble finding an actual GMC grille or do you just like the design of the Chevy grille more?
Big Chip is offline   Reply With Quote
chevy, gmc, grille.
