01-12-2022, 01:30 PM | #1 |
2WD lift kit for c20
Whats up everyone, Ive got a 1971 c20 that I want to give a little more beefy look. Ive done the 1 ton springs and spacers but it still doesn't have the right look to me. There is a guy on YouTube, harmon garage that used lift spindles for an 89-99 chevy and swapped the brakes over, tie rod ends, and ball joints. Has anyone done this on a C20. I know they make a kit for the 2500. Id like to keep my 8 lugs? Thank you!
01-12-2022, 04:48 PM | #2 |
Re: 2WD lift kit for c20
I did a 1" body lift on my truck for necessary drivetrain clearance. Purchased aluminum body mount spacers for the cab and core support and made my own for the bed.
This isn't a spring lift obviously but gives you some clearance and isn't noticeable from the outside.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" |
01-14-2022, 06:04 AM | #3 |
The member truckenrc used 2008 lift spindles - he's not active but you can do a member search
This Instagram link is more involved - lift and wider control arms from airbagit.com Also has Hanneman fiberglass fenders https://www.instagram.com/p/CSQHL6NArID/ |
01-16-2022, 08:10 PM | #4 | |
01-17-2022, 04:50 PM | #5 |
Keep us posted if you try this out! Good luck
Tags |
2wd, c20, lift |
