05-05-2022, 07:40 PM | #1 |
67 C10. 3/5 drop question
My Truck has a CPP 3/5 spring drop. Next, I want to do the 2.5 drop spindles with the disc conversion. My question is will I need to change the. Rear springs to make the truck level?
67 C10 Step Side Upgrades: American wiring, CPP Tubular Control arms CPP Sway ,CPP Pan hard Bar Cowl Hood, Rear mounted Fuel Power Steering, Classic Dash |
05-05-2022, 07:45 PM | #2 |
Re: 67 C10. 3/5 drop question
There are a lot of variables here, to say what you need for certain. However, you likely won't need to replace the springs. You could do an axle drop to level it out, just figure out how much you need and buy it. When you get to 7" of drop, there isn't much travel left, FYI.
05-05-2022, 10:46 PM | #3 |
On a coil spring truck it’s easier to get a little more drop using blocks. That’s what I would do. My leaf truck is dropped 4.5” in front and 7” in the rear with no C-notch. Once you do the front, decide how much lower you want to go in the rear and just buy the appropriate block.
05-06-2022, 07:50 AM | #4 |
Thank you guys for the helpful info!!
05-06-2022, 08:03 AM | #5 |
Good suggestions.
I'll add, drop blocks are an easy way to get additional drop. But there are consequences if getting aggressive. Drop blocks beyond 1" in height can put the rear axle scrub-line below the wheel lip if using 15" wheels. In the event of a serious tire failure, the U-bolt ends can make contact w/the road surface. Like dropping an anchor, it's not a big deal if moving unless it catches something or digs in. Wheels w/a larger diameter change the scrub-line dimension offering more wiggle room for a taller block w/o the possible contact concern. This is just something to be fully aware of when it comes to different lowering methods.
05-06-2022, 10:12 AM | #6 | |
05-06-2022, 10:19 AM | #7 |
Is it level with the current 3/5 drop?
72 C10 lwb fleetside -stock 350/350 combo |
05-06-2022, 10:27 AM | #8 |
Good question, I need to measure but Also I was waiting for the front end to settle. It doesn't have 20 miles on it since I did the front end.
