06-07-2022, 03:27 PM | #1 |
Fuel pressure issues
I’m having issues with fuel pressure. I have a gauge right before the carb and sometimes it doesn’t even come off of zero when the truck is running and sometimes it jumps around but rarely gets above 2 or 3 psi. Sometimes the truck seems to be running fine and sometimes under load it falls flat on it’s face and feels like it just ran out of fuel. I replaced the pump and the filter with no change. I ran a line from the pump to a gas can to try to rule out it being a bad pump even though it’s new, and I got a rock solid 6.5 psi on the gauge. The only thing I can think of is the sock in the tank could be clogged. Does it sound like I’m on the right track? I just though I would get a couple more opinions before I go through the hassle of dropping the tank, which is of course full.
06-07-2022, 03:56 PM | #2 |
Re: Fuel pressure issues
When was the last time you replaced any rubber lines in the system? Have you checked the hard lines for any pinholes allowing air into the system? If those are good, I'd check the pickup in the tank next
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
06-07-2022, 05:13 PM | #3 |
Moderator
I would be suspecting the strainer sock on the bottom of the tank pickup....
There are also two rubber hoses under the floor where the tank lines exit the cab and start their journey forward.... I have seen these hoses collapse and allow the feed line to the pump to cause a kink in the rubber hose, effectively acting as a restriction.
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
06-07-2022, 05:31 PM | #4 |
Just realized I didn’t mention I’m talking about my 87 c10. I think the only rubber lines I haven’t had my hands on are the ones between the sending unit and the hard lines and that also means dropping the tank.
06-07-2022, 06:07 PM | #5 |
Moderator
If you have a compressor and air nozzle drop the air pressure down to around 10 psi and remove the rubber hose from the pump that is heading back to the tank...
remove the gas cap blow air slowly thru the gas line and any trash that has s collected on the pickup sock in the tank should dislodge. If the truck runs ok after this, you should drop the tank and clean out the trash or it will just do the same thing in the future.
06-07-2022, 06:39 PM | #6 |
Ok, I tried that and it didn’t have much of an effect. I could hear air going into the tank, but when I hooked everything back up I still had barely enough fuel pressure to keep it running.
06-08-2022, 10:15 AM | #7 |
Sounds like a good time to replace all fuel lines, filters, clamps and connectors from inside the tank all the way to the carb. Maybe even pick up a new pressure gauge.
06-09-2022, 09:12 AM | #8 |
Thanks. I assumed I was going to be dropping the tank, just wanted to make sure I wasn’t overlooking something before I got into it.
06-09-2022, 07:58 PM | #9 |
Moderator
It may pay you in the long run to replace the old tank with a new unit....
Aftermarket tanks run around $90 and new sender units and pickups run around $60 depending on how many pipes go into the tank...1 or 2 or 3... If you do go with new tank, make sure you order the anti squeak strips...item 14 on the page. See LMC page as an example https://www.lmctruck.com/1973-87-che...and-components
06-11-2022, 08:10 PM | #10 |
Mystery solved. The previous owner that switched my 87 from tbi to carb used a piece of fuel line to rig the tbi sending unit to work with a mechanical pump in it basically turned to black goo and split. Fingers crossed, it seems like replacing that with a proper mechanical pump sending unit seems to have solved my problem.
06-11-2022, 08:21 PM | #11 |
Moderator
Yep...ethanol additives in todays fuels will destroy old rubber lines as you have just found out.
Might be an idea to change any other older rubber lines anywhere in the system, especially the return line if you are using one.
