11-18-2022, 07:53 PM | #1 |
Junior Member
Air Conditioning hole templates
Hello, I was wondering if anyone out there has the templates for cutting the dash holes for the air conditioning vents ? The two side ones and the upper center one. Truck is getting ready to get a paint job and I think this would be the best time to do any cutting. I plan on using factory style vents.
Thank you in advance ! Dan I have a 71 |
11-18-2022, 09:48 PM | #2 |
Re: Air Conditioning hole templates
Jim |
11-19-2022, 01:38 AM | #3 |
The factory vents are large and one has very little room to make any mistakes.
That said more than a few have done a wonderful job of replicating the factory holes. That said I used the Vintage Air vents. They are smaller and I had no difficulty drilling the holes with a hole saw. What I don't know is if the vent hoses are the same diameter? Maybe some one will chime in? Cheers |
11-19-2022, 10:17 AM | #4 |
Junior Member
Thank you
11-19-2022, 10:56 AM | #5 |
Junior Member
I'm thinking now that I should just go with an aftermarket vent kit ? I want to get the vents in before paint but won't be adding air right away. Just think it's smarter to do cutting now.
Does anyone make a nice three piece vent kit that can be purchased separately from a whole kit ? One that hopefully has templates and instructions ? Any ideas or recomendations ? Appreciate the help |
11-19-2022, 11:15 AM | #6 |
You can buy all the vents separetly from Classic parts / carandtruckshop/ most parts dealers have them . I don't think they include patterns or directions
https://www.classicparts.com/Misc-A_.../products/298/
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
11-19-2022, 10:16 AM | #7 | |
Junior Member
11-19-2022, 05:52 AM | #8 |
Aftermarket is smaller, if you have factory style vents I believe they have adapters to connect the larger size. Restrictive air flow in the case and hoses is one of the reasons I have avoided aftermarket systems for my truck. I used some templates from a kicked off member to put factory A/C vents in my truck. Seemed like a decent guy, quite a few deals with him. Pm me and I will give you his number.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 11-19-2022 at 06:02 AM. |
11-19-2022, 08:27 AM | #9 |
I had just repaired my 67 non A/C dash and was a little concered about cutting big holes in it , I found a set of vents on the board and removed the inner plastic so I could use them as a perfect pattern and not have to worry about removing too much metal or having any gaps . I used a cutoff wheel to rough out the opening and then a flap wheel to fine tune it , Worked great .
