05-09-2023, 03:53 PM | #1 |
Hydro-Boost installation
I am trying to install a Hydro-Boost unit to replace my break booster. I am trying to figure out how to properly adjust the push rod that goes in between the booster and the master cylinder. The end of the rod inside the Hydro-Boost looks like a an acorn nut. The rod that was inside my old booster sat a little less than .5 inches below the mounting surface.
05-10-2023, 10:35 AM | #2 |
Re: Hydro-Boost installation
you need a tool like this to insure that you have the correct depth and clearance between the end of the push rod and the piston in the MC
there should be between 1/32" and 1/16" clearance to insure that the piston is fully retracted in the MC when the brake is not applied
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
05-10-2023, 08:12 PM | #3 |
Thanks. I have a set of calipers can I use those?
05-10-2023, 08:30 PM | #4 |
Never mind I just watched the video and understand why I need one.
05-13-2023, 07:21 PM | #5 |
Thanks I got one off of amazon and it worked great.
05-27-2023, 07:34 PM | #6 |
So I got my hydro boost all plumbed and installed today with no leaks YAY.
I started the truck up and tried bleeding the system by turning the wheel back and forth and pumping on the brakes. The pump is making a humming noise and the steering is squeaking like crazy when I go lock to lock and when I push on the brake pedal. I am hoping that I have just not bled it enough. I was told that I don’t need to leak any fluid when I bleed it. That the pressure should escape from the spring load pump cap. Also the steering and brakes are a little shuddery especially when I am using both the steering and the brakes at the same time. I have no tried driving it anywhere yet. |
05-29-2023, 09:12 PM | #7 |
I figured out that the reason it was stuttering and squeaking was because my belt was not tight enough.
