06-26-2023, 06:30 PM | #1 |
Radiator Shroud for 6 cylinder
WTB. Looking for a plastic Radiator shroud for a 6 cylinder 292. Thank you.
08-07-2023, 05:55 PM | #2 |
Re: Radiator Shroud for 6 cylinder
Hello there. I have several fan shrouds but not sure for what radiator and engine set up. Can you help me identify what you need for your 6 cylinder.
Thank you. Dan
72 sierra grande 402/400 72 longhorn 402/400 67 swb fleet side 350/350 buddy buckets tack/vac dash project 71 Cheyenne c20 350/350 all original except seat cover-SOLD 1970 GMC 3500 SRW 350 4 speed-FOR SALE 72 c-30 bb 4 speed dump bed 72 k-20 4x4 350/350 patina rat rod---sold 80 chevy p20 aluminum step van 350/400 12 ft cargo 62 parts car & 63 project nova, 4 door 6 cy 74 Honda cb 360 only 4000 miles |
08-07-2023, 09:20 PM | #3 |
Hi Dan.
I wish I could. Mine didn't have one on it and I don't know what it looks like. Thank you |
08-09-2023, 11:03 AM | #4 |
Location: Herculaneum MO (20 minutes south of St. Louis
I'm pretty sure the six cylinders never had a fan shroud, just a finger guard. That's all my 250 had. My 292 never gets over 180 degrees anyway.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
08-09-2023, 04:07 PM | #5 |
They made them as a "Heavy Duty Radiator Fan Shroud". There was one listed on this site before. Thanks.
08-15-2023, 07:45 PM | #6 |
My 69 inline 292 came with the RPO option "heavy duty radiator" listed but had no fan shroud, just the finger gaurd. Good luck with the search. If found, please post a picture.
02-19-2024, 10:28 AM | #7 |
My 69 has a fan shroud that looks like it may have came on it from the Factory, has the old sticker on it. I bought this truck 8 years ago out of the desert in CA. I post a picture of it.
02-19-2024, 01:10 PM | #8 |
Can you tell if there are factory numbers on it anywhere? How many blades are on your fan? Thank you.
02-20-2024, 10:44 AM | #9 |
Active Member
I just ordered a new 3 row brass/copper radiator along with a fan shroud for a non a/c sbc for my inline 6 last week from LMC. Should have it by thursday this week and i will keep you informed if it works out.
02-20-2024, 11:54 AM | #10 |
I ended up buying a fan shroud from LMC for a sbc and cut it out to fit. I’m still wanting an original one for it.
02-20-2024, 03:21 PM | #11 |
Active Member
Whe you say cut it out to fit, what is it you cut out? Im under the assumption that inline 6 engines came factory with the narrower 2 row radiator which wont accept any fan shroud except the top metal cover. I was told that using the wider 3 row radiator in my inline setup would then allow the v-8 shroud to be used.
02-20-2024, 04:06 PM | #12 |
I put in a three row factory radiator as well. I had to cut part of the side of the fan shroud out and the bottom so it would fit. My truck is a 1 ton chassis.
