Old 07-04-2023, 08:08 PM   #1
65truckowner
65truckowner's Avatar
1965 c10 12 bolt axle bearing removal
What is a good way to remove old axle bearings from my 12 bolt under my 65 chevy 10? I tried my dent puller with an attachment but did not work. I also tried heating it still did not move. Any ideas?
65truckowner is offline   Reply With Quote
Old 07-04-2023, 08:30 PM   #2
v30crewcab
v30crewcab's Avatar
Re: 1965 c10 12 bolt axle bearing removal
takes a pretty good hit with a slide hammer to get them out. just did them in the 71 this afternoon. but I used an axle puller slide hammer kit.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 07-05-2023, 11:08 AM   #3
cwcarpenter98
cwcarpenter98's Avatar
I used a slide hammer for mine as well. Made quick work of them. You should be able to rent the kit from your local chain auto parts store
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 07-05-2023, 05:05 PM   #4
65truckowner
Ok thanks
Old 07-05-2023, 11:01 PM   #5
65truckowner
Ok so after trying the dent puller again I gave up and pulled the carrier again and ran a long pipe in the axle tube and drove the bearings out Now all back together with new bearings and seals.
Old 07-06-2023, 11:25 AM   #6
kwmech
That's exactly what I do when I get a stubborn one. Have a 6' piece of sacrificial 1/2'' galvanized pipe for the task. I use it more often that not.
