03-30-2024, 03:14 PM | #1 |
Rear shock mount rust ?
There seems to be a large area between my rear shock mount and the trailing arm that has some pretty serious rust going on . What do I need to do to fix this ? Do I need new rear shock mounts or can this be dealt with otherwise ?
03-31-2024, 11:18 AM | #2 |
Re: Rear shock mount rust ?
I don't have suggestions but subscribed to see what comes of this. My shock is attached on the outside of the shock mount, not inside like yours. I'm curious about that, too.
03-31-2024, 01:27 PM | #3 |
All about them K’s
It’s hard to say how bad it really is until you take it apart and clean it all up, that will determine what needs to be done to fix it. A lot of times rust can expand like that but the real damage not be too bad on thicker steel. My suggestions is to take it apart and get a flap disk on the areas in question to cut thru the rust and see what it looks like from there.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
03-31-2024, 02:16 PM | #4 |
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
03-31-2024, 05:56 PM | #5 |
As previously stated by 57taskforce only disassembling it will tell the truth.
I will add that in my experience you will need new U-bolts to reassemble it. The hassle of fighting to remove the nuts on those and the likelihood of them being compromised by the corrosion isn't worth the work. I would just cut them with a cut off disk and be done. Just my opinion and along with a ten spot they'll get you a steaming hot cup of Joe just about anywhere.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
04-01-2024, 10:23 AM | #6 |
Here's one option:
https://67-72chevytrucks.com/vboard/...d.php?t=850227 |
