Old 02-29-2008, 02:34 PM   #1
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
my radical 60 build
Those of you that have seen my posts know that I tend to like things a little radical.
this is a 1961 chev 3/4 ton cab that I was able to save from the crusher-45+ of his brothers died on 01/05/08-RIP
I was inspired by the pink freak <--in my avatar-, they used a 61 chrysler front clip, and it almost looked like it was built for the truck from the factory.
I didn't want to do an outright copy though, and while surfing the net I saw a 61 plymouth SW push car, and decided that had the right lines to graft on and looked neat.The crusher yard just happened to have 1-only one-, so I was able to get the front sheet metal as well.
As you can see in the interior and passenger side shot some mice had taken up residence in the cowl vent- they wrecked havoc on those parts rusting them clean through.
I hadnt even noticed the rust in the roof until I was inside undoing the ebrake... so I rushed back through the yard, and found a spare BBW roof on a cab that I had previously rejected due to floor rust and a telephone pole mark in the rocker.
So here start the pics:
when I brought it home 12/23/07-
WELL ISN'T THIS CRAZY- this machine wont up load my photos, I will try again later, and in the meantime check out the pic in my profile.........
Old 02-29-2008, 03:24 PM   #2
jonzcustomshop
1961 crewcab
Re: my radical 60 build
OK here we go....
I guess I have to resize all my pics, so here is the first batch:
Old 02-29-2008, 03:30 PM   #3
jonzcustomshop
1961 crewcab
second batch of how it was 12 /23 /07
Old 02-29-2008, 03:49 PM   #4
jonzcustomshop
1961 crewcab
here is the easy part: the measuring.
I let the 61 plymouth front clip dictate what I needed to cut.
There was a 6.5 inch difference in the door edges.
so that ment a 6.5 inch section(kind of scary, I didn't think it would need to be that much)
the peak in the plymouth fender did not line up with the peak in the cowl, so to get that to line up I had to take a 1 3/4 section out of the body line.
that left a 4 3/4 section to come off the bottom.
I was hoping to get away with cutting it all off the bottom, but no such luck.
Old 02-29-2008, 04:01 PM   #5
jonzcustomshop
1961 crewcab
I then measured the door.
you have to get a little crazy with the cuts in the jamb to keep all the stuff in the right spots.
I like to get at least one door cut before the body, so you can use it for reference points on where to cut the body, and fit it to the body as it is going back together.
the last shot shows a foreshadowing of the rust problem I was going to encounter with this "good" door after I cut it apart...
Old 02-29-2008, 04:16 PM   #6
jonzcustomshop
1961 crewcab
here is cutting the door:
This is my second sectioned vehicle, after doing the first one I learned that it is way easier to split the skin off the door than chase a weld down the middle of a door skin,although with this section I still have a weld down th middle of the door! At least it's not two!
after I split the skin I took 4 inches off the bottom, that leaves me a little metal to fold over the skin of the door for the 4 3/4 section of this part.
Old 02-29-2008, 04:28 PM   #7
TimE
Hey Y'all!!
TimE's Avatar
Wow! That is some intense measuring/cutting/splicing going on there. Looks like it will make a sinister looking car..I mean truck, once you get it together. Keep the cool progress pics comin'.
TimE is offline   Reply With Quote
Old 02-29-2008, 04:41 PM   #8
jonzcustomshop
1961 crewcab
here is the line out of the cuts for the cab:
once again in the rear door jamb, I am cutting around what I don't want moved.
On the corner you can see where the two different sections come out.
On the bottom cut I found the flattest part of the cab side, and then used the peak of that as the center of my 4 3/4 inch cut , so that the two pieces would line up when they came back together.
I chose one cut down the center of the back of the cab to cut down on the welding and chance of warpage.
the front was alot easier, every thing was straight and covered by sheetmetal, so I just took 6.5 out of the center of the door pillar.
You can also see where I will cut straight down the edge of the door pillar, and across the toe panel.
All I will have to do with the firewall is trim the bottom off, and fold it up to meet the floor.
Old 02-29-2008, 04:53 PM   #9
jonzcustomshop
1961 crewcab
here is folding the fire wall back, and fixing some rust issues.
I almost didn't put a drain in the new cowl vent by accident-that would have been a flood on the first rain!!
Old 02-29-2008, 05:14 PM   #10
jonzcustomshop
1961 crewcab
here is fixing the rust in the rockers of what i thought was a "rust free" cab... Oh well.
and then on to fitting the door.
I bolted on and latched the top part, and then the bottom,.
I ended up trimming about 1/8 of an inch off of my cut to get the door gap lined up, then I welded them together.
Old 02-29-2008, 05:20 PM   #11
jonzcustomshop
1961 crewcab
Here it is all tacked together and mocked up.
Now I have about 50 yards of welding to do 1 inch at a time!
the last pic is my photo chop idea for the rear end.
I have a couple 60 GMC hoods that I can cut up to make the tail light housing, and the bumper will be a 59 chevy.
Old 02-29-2008, 05:35 PM   #12
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Hey JonzCustoms.....cool name, BTW.....
Dude, that s#it is gonna be SICK !!! I like it !!!
I've always wanted to do a chop and channel, but I guess I haven't found a good candidate....I have a '56 Oval sitting in my garage I could use (suppose to save it for little John...he's only 7 now) Don't want to touch the Chief...it's in decent shape.
Anyway....You talking a Impala bumper, right ??
Way cool, bro
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 02-29-2008, 08:46 PM   #13
slepysal
slepysal's Avatar
very very cool. Man that is going tolook crazy ! So what are you going to call her ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 02-29-2008, 10:58 PM   #14
Frizzle Fry
Frizzle Fry's Avatar
I like that front clip on there. Great work on the section.
Frizzle Fry is offline   Reply With Quote
Old 02-29-2008, 11:25 PM   #15
jchav62
1962 C-10
jchav62's Avatar
That's some heavy stuff! Cool...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 03-01-2008, 12:15 AM   #16
72BlckButy
Tot Roddin'
72BlckButy's Avatar
This is going to be one sick and twisted ride!!!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-01-2008, 12:50 AM   #17
Dinos63
chevy only
Dinos63's Avatar
My New Hero, Jon Wow Bad A$$
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 03-01-2008, 01:13 AM   #18
ryan913
Boy that is a lot of custom work. Looking good!
ryan913 is offline   Reply With Quote
Old 03-01-2008, 01:18 AM   #19
283 Man
283 Man's Avatar
sweet!!!!!!!!!!
283 Man is offline   Reply With Quote
Old 03-01-2008, 01:21 AM   #20
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: my radical 60 build
Now that's pretty cool. You do not see that much now days. Chopping, Channeling, Sectioning. For some guys it's, "Say what?"
CHOPPING:
To chop a roof the pillars and windows are cut down, lowering the overall roofline. "Chopping the top" goes back to the early days of hot rodding in an attempt to reduce the frontal profile of a car and increase its speed potential. Some racers on the dry lakes chopped the tops of their cars so severely that the windows were only a few inches tall. These were sometimes referred to as "mail slot" windows. This sort of bodywork is also popular on custom cars, kustoms, and leadsleds. Roof chopping also quickly became very popular with drag racers for much the same reasons as it did for lakes racers. The first roof chopper is considered to be Sam Barris who chopped and customised his brand new 1949 Mercury. Barris also pioneered a more advanced form, where the B-pillar is removed turning it into a pillarless hardtop in the process.
CHANNELING:
To Channel a car the body is also lowered over the frame by removing the floor & refastening it higher inside the body, causing the body to rest closer to the ground without altering the suspension. The overall effect is to give the car body a more massive appearance. Each automobile would have its own engineering challenges as far as modifying the various components of the chassis. Local laws may prevent making the modifications too extreme, and safety would dictate some restraint. Channeling is also popular amongst hot rod, leadsled and minitruck enthusiasts, though the latter refer to it as a "body drop".
SECTIONING:
A related process to channeling a car (and one that has almost the same aim) is Sectioning. Sectioning is the act of removing a horizontal section from the body of a car, lowering the top half onto the bottom half and welding the result back together. The purpose is to reduce the overall height of the bodywork of the car. Likle a roof chop, it also has the advantage of reducing a car's frontal area and reducing wind resistance. This sort of bodywork is popular on minitrucks, custom cars, custom trucks, kustoms, and leadsleds.
This is what OLD SCHOOL means!!!!!!!!!!!!!!!!!!!!!!!!!
This what's cool!!!!!!!!!
This was the thing in the 1950's and early 60's!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 03-01-2008, 04:16 AM   #21
protrash64
Resistance is Futile
protrash64's Avatar
..........Kick a$$!!!!!!!!!!!!! that some wicked stuff, dude! Im sure lilred66 is furiuosly stabbing needles into a pic of your avitar!!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-01-2008, 06:42 AM   #22
hewlett2002000
hewlett2002000's Avatar
so what is it an el calymouth?
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 03-01-2008, 07:06 AM   #23
greg64
greg64's Avatar
Cool metalwork Jon! My hat is off to you guys; I'm more adept at mechanical and electrical.
Keep sending us pictures of the progress!
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 03-03-2008, 03:20 AM   #24
jonzcustomshop
1961 crewcab
Thanks for the compliments guys!
chiefroca,yes a 59 impala bumper off my 4 door, and that one is getting a 59 buick bumper.
62 pro street- this truck will probably get a chop (2 inch) too. That second to last truck you pictured is the rod& custom dream truck, I got a ride in that when I was 12, and it was an early inspiration to me!
protrash: probably the only reason I might be off the hook with lilred66, is because this is a 60 not a 456!
hewlett: no I hadn't thought of a name .. but El calymouth is funny!!
Update: I found a decent long fleet box for $75, as a bonus it is white too!
I have also procured a donor for the frame and motor.
It is a 85 chevy wagon.
The guy just put a goodwrench 350 in it , and it has a 2004r tranny,
I plan on using the frame, suspension, radiator, motor and tranny, gas tank, and wiring harness out of that car.
The wheelbase is 115 , and to get the vehicle in proportion I will stretch it to 119, that will let me cut down my long bed to 7 feet.
So this week I have alot of stripping (car!) ahead of me, and hopefully soon I can get the cab and front clip mocked up on the frame.
Old 05-16-2008, 01:07 PM   #25
jonzcustomshop
1961 crewcab
Well progress has been a little slow these last 2 months.
I have been busy with my 65 DD, and I have been scrounging parts.
the rh door I had was junk, so I found a better one to use, and I have that cut and tacked up.
I also got the wheels and tires squared away, which is important to get done first on a build like this.
What I will do is install these on the wagon doner car before I strip it.
then I will take frame and suspension clearance from the ground.
That way when I go to chanel the truck cab over the bare frame, I will know the clearence difference of the vehicle fully loaded ,glass sheetmetal ect..
I want to get this as low as I can without losing all the clearance-our local roads aren't the greatest-.
the wheels are Fenton Gyro Racing wheels, and the tires are 205 70's for the rear, and 195 65's for the front.
