#51 |
![]() Join Date: Sep 2009
Re: Boyd Welding-67-72 Rear Mount Aluminum Tank
I would assume that moving the mounts anymore would not leave enough clearance for fittings and sending units. this product is a model of MSGROSS's tank and drawings i did not design nor ever install one personally.
Dave Boyd View Our 63-72 C10 Tank options https://fueltankparts.com/collections/63-72-c10-tanks Boyd Welding Main Site : http://www.boydwelding.com/ Boyd Online Shop: https://fueltankparts.com/ E: Sales@boydwelding.com |
#52 |
I can remeasure mine if you want. I think it can be move up an extra 3/4" or so closer to the bed crossmember. The crossmembers are tall enough to clear sending units so that shouldn'e be an issue.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#53 |
Mike i really appreciate all your help!!!
#54 |
VA72C10
![]() Join Date: Mar 2008
I'd appreciate it if you could check. I might also modify that crossmember to tuck it up even higher but I at least want it up to the top of the frame rails if possible. Thanks.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#55 |
motor exploder
bump for a great price!! Is there a deadline for this buy? I have my truck blown apart at the moment, so now would be a good time to swap the tank to a frame mounted one.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
#56 |
Dave I ran across your site a little while ago searching for custom tanks then came in only to see this post. Must be a sign.
![]() I want to do a bumper fill also but I think the dimensions are going to need to change quite a bit for that. I'm waiting on my bumper to come in (Brothers is taking their sweet time) so I can get it bolted up and get some measurements. I think the fill neck will have to be at the bottom of the frame rail to get enough angle to fill the tank properly. I'm not real sure about that though since I don't have a way to fab it up yet. Couple of questions though, can you bend (rolled, not square) the lower part of the tank instead of weld so there are only seams showing on the sides? (bends would be front and rear and sides welded in) The top could be welded all the way around since it won't be seen once the bed is on. Also, do you do anything to reinforce the sides where the mounting tabs are? Seems like a lot of weight on a small tab that could stress over time. Thanks for your time and I'll send you some drawings and dimenstions as soon as I can. MD Last edited by Dynomutt; 10-07-2009 at 01:23 AM. |
#57 | |
![]() I just finished a tank with the exact requirements yesterday so no problem. your price will reflect that option. At this time i do not do anything to the inside of the tank ends however that can be done also. call me when your ready and we can discuss pricing and options.
#58 | |
Well I have not set a deadline as of yet but i was thinking of getting this organized and underway around the first week of November. What do you guys think. Reason for that is I will be closed Oct 22-26th (still available Mobile) and to give people time to get their ducks in a row I will post a new thread only for this group buy so that there is no confusion over what your buying, whos involved and what the terms are.
#59 |
Dave, another quick question - what sort of filler tube is gonna work so that you can flush mount it in the bed?
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
#60 | |
If this tank is identical to mine then the filler neck falls in between the metal slats for a wood bed. Steel bed guys might want it moved to the center or far side. This will require a one way check valve, that's why there is a 3/8" threaded bung on the top. they make them in different sizes as well..
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 10-08-2009 at 08:26 AM. |
#61 |
VA72C10
I'm putting my filler in the driver's rear stake pocket with a pop up flush cap from a motorcycle. Will that 3/8 check valve down on the tank work or will I need to run the vent up to the actual fill neck?
#62 | |
Air has to come out when filling at the pump and air needs to come in when running the engine.. the different locations of these keep them from spilling an liquid during normal driving. Everyone also knows what happens to gas in a non-vented plastic container, it swells and blows ![]()
#63 |
Count me in for a standard. Have a few questions though... I am gonna flush mount a ventless cap in the wood bed, am I going to need a second bung hole for two vents or is the one hole ok. Also I need the filler neck to at least be somewhat centered in a wood plank does anyone know for sure how far off it is on a fleetside?
#64 |
here's what I'm laying out for a steel bed, with EFI.
I sent this to Dave to review...anybody else see something here let me know.....I basically took msgross' drawing and tweaked it a bit. My measurements would put this about 1/4" clearance to the bottom of the bed cross sills. So you could move the side flanges down to 4" if you wanted it TIGHT against the bed. I left some room to run wires if needed. capacity calculates to 19.6 gallons BTW. Thanks, Andy
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear |
#65 | |
VA72C10
#66 |
![]() Join Date: Jul 2009
I was wondering the same thing texas67chevy. msgross, can you confirm if your design will allow some adjust of moving the tank side to side to center within a wood plank if neeeded? Thanks
#67 |
My design will allow the filler to fall in the center of the plank. You can't go center of the wood bed unless you want to cut one of the metal strips holding the bed wood down. post #29 has my tank plans.. the side brackets could be adjusted for a tighter fit against the bed cross sill.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 10-10-2009 at 11:59 AM. |
#68 | |
any royalties for the design? ![]() Here are some more pics. 1st: you can see the wood bed mounting holes in the crossill, it's darn near perfectly in the center or you have 3/4" of travel left or right.. 2nd:It could be raised 3/4" or shorten the tank for even more clearance. It has approx 3/4" on the sides as well as below the crossill, I wanted a little extra room incase I do a trap door filler with the cap that's on it. 3rd:This is a fleet short bed and it hangs about 5" below the fram rail in the rear and maybe 7-8" in the front. I made it slant downward in the front so you can drink every drop of fuel since the outlet is in the front passenger corner. If anyone else needs pics or measurements i'll leave it mocked up for another day. ![]() ![]() ![]()
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 10-10-2009 at 04:47 PM. |
#69 |
![]() Join Date: Sep 2006
what gauage alum are you using for the tanks
#70 |
Thanks msgross, thats exactly what I was lookin for... Im down for a standard tank for sure.
#71 |
For sure. msgross, thank you for your help.
#72 |
Here's an update to the drawing...the side fill will just have 2 pcs welded like shown.
The material is 1/8 aluminum as listed in the first post. Other notes: there are 0.625 radius shown on 4 of the edges of the tank, these are bent edges and won't be weld seams. Basically the tank is 2 "U" shaped pieces that are fit together and welded. EFI version will have baffles added, and a Walbro GSS342 pump with a sock filter on it. The return will be on the passenger side somewhere and will return fuel in an area outside of the baffled pickup so fuel aeration is minimized. I have experience with the GSS342's, they are a great pump. At 14v running pressure is approx. 60 psi, perfect for GM fuel injection setups (Gen III or IV). This pump is supporting 500 rwhp in my LS1 GTO and been in there for 27K miles daily driven. So I'm very happy with the performance and longevity. If you have Carb setup now, and thinking EFI later (which I am) then there are pressure regulators that will work with the high inlet pressure and bump down to the 7psi or so that a carb wants. Will return a good bit of fuel but should work just fine if the return line is sized large enough. I eventually want to "grow into" and EFI setup when funds and time allow...so this will be one less hassle when I'm ready. Cheers... Andy
#73 |
VA72C10
Wouldn't that side fill need to be a little lower for bedfloor clearance? Or is that assuming you are leaving the side brackets where they are and not the additional 3/4"
Dave Boyd.... If I do the side fill on mine, have the side flange 3/4 higher so the tank fits flush, and take 1" off the bottom, would that change the pricing at all? Also, any chance of me paying today or tomorrow to get mine produced as soon as you have time? I am ready for my tank as soon as I can get it. Mine is carb setup...not EFI...
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 10-13-2009 at 10:45 AM. |
#74 | |
If you push the top of tank up flush to the cross sills, then yes the top of the side fill would be tight to the floor. Might need to lower the side fill overall height if Dave can do it. The steel bed cross members are 3" deep from what I measured.
#75 |
I HAVE POSTED A NEW THREAD FOR THE GROUP BUY HERE
http://67-72chevytrucks.com/vboard/s...d.php?t=367055 PLEASE USE THAT FOR INQUIRIES DIRECTLY RELATED TO THE GROUP BUY.
Tags |
67-72 truck, aluminum tank, boydwelding.com, fuel tank, tank relocation |
