Old 09-18-2016, 06:53 AM   #26
toddoky
Re: LT1 GenV swap
Originally Posted by 87chevy.com View Post
Did it keep the vacuum pump? Hope so.. can't wait to get my ls-lt water pump adapters in and offer the rest up for sale ..only 4 though.
Can't find anything linking a lt1 to a ls fead setup but it looks like it would or could clear a vacuum pump.
No, the vacuum pump was not retained as it won't physically fit in most LS swap applications. The pump is only used in truck applications to augment the vacuum signal when the engine is operating in cylinder deactivation mode, so if will not be needed by someone that is not interested in utilizing that function in their swap.
toddoky is offline   Reply With Quote
Old 09-18-2016, 11:01 AM   #27
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: LT1 GenV swap
Good to now .. wonder where they are drilling and taping the hole for vacuum. Be interesting to see the holley setup.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 09-26-2016, 01:57 PM   #28
87chevy.com
Re: LT1 GenV swap
added a pic of the adapter
The other hole is also misaligned... again close enough, but no cigar.
Feeling relieved!
CNC ported FTW
Can barley tell there's a transition from the adapter to the engine block ports!
Mmm 4 sets for sale.
Gonna source some m8x120 bolts and mock it up but it's exactly how thick I wanted it
Clint
Old 09-26-2016, 03:43 PM   #29
cornerstone
cornerstone's Avatar
Re: LT1 GenV swap
Looks great Clint.... nice work.👍🏼
cornerstone is offline   Reply With Quote
Old 09-26-2016, 09:59 PM   #30
87chevy.com
Re: LT1 GenV swap
Installed
.06" gap with no gaskets installed. Add the 2 gaskets add another .070".. Plenty.. the Dirty Dingo adapters were thicker and the belt was a pretty close to the edge of the pulley, it would work but these are as close as I wanted it to get, which will put the belt more centered/away from the edge of the pulley.
Old 09-27-2016, 10:40 PM   #31
87chevy.com
Re: LT1 GenV swap
I thought I'd let you guys know that Holley will soon be releasing an LT FEAD system as well and it is based on the use of an LS water pump and uses the existing Holley LS alternator/PS pump components/brackets also. It was previewed at LS Fest last weekend and I can post a photo of it next week if you guys want to get a look at it.
Got a reply from Holley today, there is no LT accessory drive at this time..just want to keep the thread up to date.
Old 09-28-2016, 02:15 PM   #32
toddoky
Re: LT1 GenV swap
Yes that's correct, the Holley LT accessory drives are in development at the moment and not yet available.
Old 09-28-2016, 09:32 PM   #33
87chevy.com
Re: LT1 GenV swap
Are you allowed to post the picture? I think I read you work at holley correct?
Old 09-28-2016, 11:30 PM   #34
87chevy.com
Re: LT1 GenV swap
If anyone's interested 140 shipped for a pair of adapters, no bolts or hardware.. not planning on a 2nd order at this time so 4 sets is all I will have to sell. These also don't have a npt port on the passenger side like the DD ones. I chose not to have it made into it since not everyone, myself included wants it. Plus, npt taped holes are sealed with the threads and Teflon and can done by anyone with one hand and one eye and minimal tools which if your doing this swap you have .. hopefully...
Clint
Old 09-29-2016, 10:12 AM   #35
toddoky
Re: LT1 GenV swap
Sure, I can post a photo; I was waiting to get access to the engine to be able to take one. Yes, I am the design engineer at Holley who is responsible for the development of all the Hooker LS engine swap system mounting and exhaust components.[IMG][/IMG]
Old 09-29-2016, 12:26 PM   #36
87chevy.com
Re: LT1 GenV swap
Thanks for the picture. What's the solution to a vacuum source? Drilling and tapping the truck manifold or electric pump? Will there be other fead setups or just this one pictured.
Thanks Tod,
Clint
Old 09-29-2016, 12:31 PM   #37
toddoky
Re: LT1 GenV swap
Thanks Tod,
Clint
I'll have to check on the answer to your vacuum source question. I think this system will be it for the LT1 engines and we are working on a different system for the supercharged LT4 engines as well for release next year.
Old 10-01-2016, 03:34 PM   #38
cornerstone
Re: LT1 GenV swap
I spoke with the VP of sales and marketing, Wayne Powell, from Kwik Performance today at the good guys show at Texas motor Speedway. They have an A/C and alt. bracket set up that comes with a type 2 power steering pump that works with the factory L83 truck water pump, leaving the vacuum pump in its factory location. I think He told me it is $535 or so shipped to your door. You still would need to provide your own reservoir for the power steering pump. Sorry for the sideways photo.
Old 10-01-2016, 06:29 PM   #39
cornerstone
Re: LT1 GenV swap
Btw Wayne with Kwik was very knowledgeable and ready to do business.
Brian
Last edited by cornerstone; 10-01-2016 at 06:41 PM. Reason: Posted twice for some reason.
Old 10-02-2016, 12:33 PM   #40
87chevy.com
Re: LT1 GenV swap
Thanks, but that looks silly to be honest. I'll post up a pictire of the adapters I'll be making.. simple and pleasing to look at
Clint
Old 10-02-2016, 10:40 PM   #41
cornerstone
Re: LT1 GenV swap
Hahaha! Its funny how asthetics are as important as function. Im with ya... Are you going to make extras to sell on those also? I liked the KWIK setup because the PS pump is low and looked simple to plumb, a short distance to the gearbox.
Old 10-03-2016, 03:12 PM   #42
87chevy.com
Re: LT1 GenV swap
Looks like the brackets were reused from the ls fead... are the head bolt layout the same? I'm still puzzled why they decided to move the alt to the driver side, it would require a separate harness to extend from the original location to the new.
Clint
Old 10-03-2016, 03:28 PM   #43
Hart_Rod
Hart_Rod's Avatar
Re: LT1 GenV swap
Here's a bracket I made to work with the TVS1900 I put on my engine with the Holley brackets:
Hart_Rod is offline   Reply With Quote
Old 10-03-2016, 03:35 PM   #44
toddoky
Re: LT1 GenV swap
Clint
That's a good observation on your part, the brackets are the exact same ones used in the Holley LS FEAD drive set-up, which are adapted to the bolt pattern of the LT engine by means of the adapters in-between them both. This configuration was beneficial in keeping cost in check so that pricing will close to what the LS set-up is. The alternator position won't be preferable by everyone, especially those using a stock take-out ECU and wiring harness. For those going with an aftermarket EFI system like those from Holley, then the connections needed are just as easily made as if the alternator was mounted elsewhere. I know our beloved GM trucks are the focus of this forum, but there are many more applications Holley makes swap parts for that require configurations or designs that are not necessarily optimized for our trucks.
Old 10-03-2016, 07:24 PM   #45
87chevy.com
Thumbs up Re: LT1 GenV swap
Of course, I'm a master tech for BMW and one thing I know is you can't please everyone.. but appreciate the support holley is offering though
Does the holley brackets fit a stock lt1 alternator?
This is basically what it is.. it woukd use the captors alternator and tensioner... gonna need to put the intake on it, but it should be 0 problems with that, and ad far as hood clearance, it's only raised maybe 1-2 inches... if the intake is higher than the alt, no problems
Old 10-03-2016, 08:00 PM   #46
toddoky
Re: LT1 GenV swap
I'll have to find out for you as I'm merely the information middle man on these components.
Old 10-05-2016, 10:39 PM   #47
87chevy.com
Re: LT1 GenV swap
Minor parts
Oil cooler bypass cover just incase the oil cooler manifold doesn't fit.
Old 10-06-2016, 08:30 PM   #48
87chevy.com
Re: LT1 GenV swap
And the long awaited fuel pump driver module connector.. brought 2nd one to use for one additional harness
Besides the belt drive that's almost worked out and motor mount adapters I think I'll be ready for the swap.
Old 10-07-2016, 10:31 AM   #49
toddoky
Re: LT1 GenV swap
87Chevy.com, the Holley alternator bracket will accept the LV3/L83/L83 truck alternator, but not the LT1/LT4 alternator. This is due to the mounting hole spacing difference between them.
Old 10-07-2016, 03:12 PM   #50
87chevy.com
Re: LT1 GenV swap
Cool, thanks for the details.
Clint
