#501 |
Under Construction
Re: New project
B@d A$$ truck...
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#502 |
mini truck racer
Re: New project
Went out 4th round in no box , but won super pro Saturday . Sundays races rained out .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 03-13-2018 at 10:26 AM. |
#503 |
mini truck racer
Re: New project
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
#504 |
mini truck racer
Re: New project
#505 |
mini truck racer
Re: New project
Won 10.50 index at TX2K18 !
#506 |
![]() Join Date: Mar 2008
Re: New project
Good Job Hotrod. How many rounds did it take?
NHRA Super Street 469C It only runs 10.90 at 156 mph |
#507 |
mini truck racer
Re: New project
#508 |
mini truck racer
Re: New project
5 rounds 16 car field and you had to qualify . 24 cars total . but they only took 16 .
#509 |
mini truck racer
Re: New project
Ran the Houston performance trucks ( HPT ) shootout this weekend with both trucks . I took the yellow truck out to run the 10.0 index and my buddy Jay came and got my Blue street truck to run 12.0 index . The weather was horrible 72 and mist. The track hung with it through a cold front coming through and put us on a good track for sure . Last year I was 10.04 . This year fastest pass was 10.22 . Hard to win leaving a quarter second on the table . I would typically spray , but the air went from 1800 DA to -961 in a matter of hours . I was worried about hurting something here at the first of the season with the points lead . The blue truck came out swinging . It went 12.04 out of the trailer and with just removal of the air cleaner it went 11.70 . So we go to work . Jay had the largest field in the show and had to go 2 extra rounds for the win . I ended up going to 3 trucks just off the tree (.400 pro tree) and got to third round and imo was late @ .071 . The guy I was running was .198 and able to run 9.80 in a S-10 twin turbo truck and run through nose to tail with me for a 10.01 to my 10.22 . I also ran the 6.50 cash days shootout Were in the semis finals I put a new personal best of 1.41 60" on motor for a break out of 6.487 lifting at about 580 foot and taking a 18 wheeler length of strip . Temp settled at around 46 degrees by the end of the race . Still a fun weekend , Here are some of the pictures .
Open time trials ![]() ![]() ![]() The blue square body was the 10.0 index winner . Single turbo junk yard 5.3 ![]() Jays pairing for 12.0 finals ![]() ![]() We had 3 people ask us about electronics which are not allowed . The blue truck doesn't even have an MSD box . It is a 388 with a HEI off Ebay that is a footbrake deal . No transbrake .
#510 |
Re: New project
I really like that white S10. Very cool pics. Looks like you are having fun.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#511 |
mini truck racer
Re: New project
I learned a lot from these guys . The blue square body was air to air intercooled 5.3 and the white S-10 was waster to air under the intake hat . I think it was a 4.8 with 2 small turbos . I was down on power and didn't want to risk killing a motor with my on the edge nitrous tune up . Both great guys . Think my big tire project is going LS single turbo on E85 now .
#512 |
mini truck racer
Re: New project
Well I had a points lead in super pro / box class going into this weekend . We rain delayed until about noon and they put us a great track together . After second time trial I was changing my 2 step point from 3900 to back to 3600 . and forgot to disconnect the fuel pump. Hydro locked the motor with fuel . Pulled the plugs , and blew the fuel out , but man it started smoking . I worked my way down to 12 cars in super pro or box class Saturday night . Got up sunday thinking I was headed into a good day of racing . Well that went down hill quick . Appearently o broke the starter bolt off in the block by the outside ear . and the second bolt bent right after first round . I was double teched in no box/footbrake and box class . And was the last car up there . We rolled upder the tower and I crawled under the truck and held the starter in place while a buddy started it up . I was rattled badly and in a rush to get suited up and belted in . I was .039 to his .013 and went 6.424 on a 6.41 dial . he slid across the finish line with the front brakes locked for the win. I jacked it up and got the broke bolt off and a new set of bolts put in . Last car in the staging lane for round 2 in super pro . Ended up being .010 red . Brought it back to the pits and when I killed it and it hydro locked again . Found the back float stuck open.
#513 |
mini truck racer
Re: New project
I tore into it today . I checked the fuel pressure and it was dead on 6.5 psi . Drained the tank , cleaned the filter ( wasn't bad ) . Then pulled the rear bowl . Float level was to high . I miss read the instructions . It said fuel to the bowl inspection plug threads and 2 turns . This meant 2 flats or ad 1/3 turn. Once I left ( the starting line ) the fuel pump would force it to spill over making it just rich enough to kill some numbers . Then when the motor would use enough to lower the level it would run out the back clean. Should be good to go . Going out Friday to test and make 1/4 mile passes to see if I can get enough cylinder heat to reseal the rings.
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 05-09-2018 at 08:06 PM. |
#514 |
mini truck racer
Re: New project
about to try this thing out Friday .
![]() Oh and guess who is leading box class with out a delay box ? ![]()
#515 |
mini truck racer
Re: New project
Redemption 12.0 no prep . What a great time . Runner up in 7.0 Friday night . Lost on a double breakout and got to 6 cars in 6.50 index Saturday and spun , but was less than a half a car at the finish for the loss. Had a great time , met some new friends and came home with some money .
#516 |
Re: New project
you have been killin it. Good job! Good luck in the points.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#517 |
mini truck racer
Re: New project
Thanks we have a 2 day coming up June 2nd and 3rd . with a 5k jackpot for no box and a 10k jack pot for box after the race Saturday.
#518 |
mini truck racer
Re: New project
Well what a scorcher. Over 100 degrees both days . We ended up going out at 5 car Saturday during the bracket race . Was in the no box gamblers race and ended up with the win at like 1:30 am . Then Sunday lost at 3 cars . 3 races = 2 checks and some cash. Pretty good weekend .
#519 |
mini truck racer
Re: New project
I have literally beat the crap out of this thing lately . So I put it in the garage for a good look over yesterday . Had 5 valves with more than .030 lash . Just set everything back were it needed to be . Oh and the rear bowl was spilling over due to being set wrong , but the front was also set wrong so I fixed that . One electric fan wasn't working , fixed that . Tires are done so I bought 2 pair of slicks . I still have a decent set to run on while they come in . Plans are to check the brake pads and sample the trans fluid and rear end fluid change . I think I'm gonna try a set of 29,5Ws for no prep and see how that goes .
#520 |
mini truck racer
Re: New project
broken sprag in the converter 3rd time for this.
#521 |
mini truck racer
Re: New project
Runner up at pinevalley in no box . Running 6.60 index tomorrow night . I ended up with a FTI 8" with mechanical diode . Have my back up ATI glide in it . So far so good . Sent my ATI converter off and had stator replaced and 22 element sprag installed in it and Hughes ( primary ) trans is in for inspection and freshen up . The new DRP transbrake button is working nicely for me . Working on a different picture host as imgur is a pain in the but and doesn't seem to work half the time.
#522 |
mini truck racer
Re: New project
Runner up in 6.60 index . 2 day wally race this weekend . Double teched in box and no box as usual.
#523 |
Re: New project
Good Luck Hotrod
#524 |
Re: New project
time for a update
hope yall are doing well Hotrod, since the last storm.. lost my internet, but it only took a year to fix it.. lol . JJ
JJ 71 SWB 360 Th400 4.56 ![]() |
