Old 10-01-2019, 12:47 AM   #1
67see10
67see10's Avatar
LS Wire Harness Connectors
Is there a list of part numbers for the connectors on a ls harness? I have more than a few broken connectors on a harness that I need to replace.
67see10 is offline   Reply With Quote
Old 10-01-2019, 09:30 AM   #2
Gregski
Gregski's Avatar
Re: LS Wire Harness Connectors
for the two or three that were wonkey on mine I just went to the local PnP and snipped them off of the harness, I made sure not to jack up a good one so I found some that were already torn apart, I figured better to replace OEM connectors with OEM rather than aftermarket junk, but simply Google it we find EFI:
https://www.eficonnection.com/home/c...ors/connectors
Gregski is offline   Reply With Quote
Old 10-02-2019, 09:38 PM   #3
Wildkarde
efi connection is great for replacement connectors. You can get empty bodies and pins as well as pigtailed connectors if you don't have the right crimp tools.
Wildkarde is offline   Reply With Quote
Old 10-03-2019, 09:16 AM   #4
Willie Makeit
Willie Makeit's Avatar
Mouser Electronics is the place but you will need to know the Delphi part numbers.
Willie Makeit is offline   Reply With Quote
Old 10-03-2019, 02:39 PM   #5
kipps
An Alldata subscription for your donor vehicle will give those part numbers. At least it worked on my 2010. There's numbers listed for each connector and terminal.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 10-03-2019, 03:37 PM   #6
Willie Makeit
No charge.
https://ls1tech.com/forums/conversio...rs-inside.html
Here is a link to the Delphi parts catalog. It doesn't show specific applications, but it does give part numbers.
https://www.reynoldsonline.com/ASSET...4580L_Broc.pdf
Old 10-03-2019, 03:46 PM   #7
dayj1
Agreed. This has most any Delphi part number needed for an LS swap.
https://www.powerandsignal.com/docs/...%20Catalog.pdf
Edit: Jinx! Willie found another catalog scan at about the same time.
dayj1 is offline   Reply With Quote
Old 10-03-2019, 04:06 PM   #8
Willie Makeit
dayj1 is from whom all knowledge is gained.
Old 10-06-2019, 09:37 PM   #9
67see10
67see10's Avatar
Reposting this info from JayinMI on ls1tech:
Lets get started with the Engine connectors:
https://ecat.aptiv.com/feature?search=15324165 Crank Position Sensor 15324165
https://ecat.aptiv.com/feature?search=12059595 Cam Position Sensor 12059595
https://ecat.aptiv.com/feature?search=12129946 MAP Sensor 12129946
https://ecat.aptiv.com/feature?search=12047938 Coil Pack Connector 12047938
https://ecat.aptiv.com/feature?search=15449028 ECT Sensor 15449028
https://ecat.aptiv.com/feature?search=13602480 Oil Pressure Sensor 13602480 Updated 2/21/18
https://ecat.aptiv.com/feature?search=13602480 A/C Refrigerant Pressure 13602480 Updated 2/21/18
https://ecat.aptiv.com/feature?search=15305555 5 Wire MAF 15305555
https://ecat.aptiv.com/feature?search=12059595 3 Wire MAF 12059595
https://ecat.aptiv.com/feature?search=12162197 2 Wire IAT 12162197
https://ecat.aptiv.com/feature?search=12052644 Coolant Level Sensor 12052644
https://ecat.aptiv.com/feature?search=15492640 80 Pin PCM Connector 15492640
https://ecat.aptiv.com/feature?search=15326836 DBW Throttle Body 15326836
https://ecat.aptiv.com/feature?search=12186568 Alternator 12186568
https://ecat.aptiv.com/feature?search=12162017 A/C Clutch 12162017
https://ecat.aptiv.com/feature?search=12052641 Knock Sensor (PCM Side) 12052641
https://ecat.aptiv.com/feature?search=12124037 Evap Canister Purge 12124037
https://ecat.aptiv.com/feature?search=15326423 Square HO2S Connector 15326423
https://ecat.aptiv.com/feature?search=12092839 V-shaped HO2S Connector 12092839
Fuel Delivery:
https://ecat.aptiv.com/feature?search=15411634 Multec 2 (Truck) Injector 15411634
https://ecat.aptiv.com/feature?search=15305086 EV6 Injector 15305086
https://ecat.aptiv.com/feature?search=15497399 EV6 USCAR Injector 15497399
https://ecat.aptiv.com/feature?search=12129142 EV1 Injector 12129142
https://ecat.aptiv.com/feature?search=13511131 Fuel Composition Sensor 13511131
Transmission:
https://ecat.aptiv.com/feature?search=15449028 VSS/ISS Sensor 15449028
https://ecat.aptiv.com/feature?search=13595247 Main Transmission 4L60E/4L80E 13595247
https://ecat.aptiv.com/feature?search=12129840 Park Neutral Pos. 12129840
https://ecat.aptiv.com/feature?search=12191757 Trans. Range Switch 12191757
OBDII:
https://ecat.aptiv.com/feature?search=15317575 Clip-in Style OBDII Plug 15317575
https://ecat.aptiv.com/feature?search=12110250 Screw-in Style OBDII Plug 12110250
TAC Module:
The 16pin TAC Module plug is 2 pieces + terminals/seals/locks.
This is the part that goes between the TAC Module and the DWB Throttle Body.
https://ecat.aptiv.com/feature?search=12191068 Strain Relief 12191068
https://ecat.aptiv.com/feature?search=12191065 TAC Connector Body 12191065
Old 10-08-2019, 01:52 PM   #10
Daaaanz67
67see10, for gen 3 LS right?
Daaaanz67 is offline   Reply With Quote
Old 10-08-2019, 02:52 PM   #11
67see10
67see10's Avatar
Yes
