![]() Join Date: Jul 2013
Im at a loss. My 5.3 has fired right up every time I have tried...until after doing an oil change today and getting ready to tow it to the driveline shop. Fuel pump is working and I can smell gas while it cranks but wont fire. Has 1 trouble code p1518 which has to do with the TAC module...i have checked all of my wiring, checked my fuses. I am at a complete loss. On the bright side I tried to start it before calling the tow truck, would have sucked to pick it up from the driveline shop for it to not start and need towed again.
Re: 😵
Not sure if it's your problem, but I have had the plugs get gas fouled while starting a swap engine many times before everything is hooked up. Try taking the plugs out and see if they're wet. If they are, I have had decent luck burning them off with a propane torch then reinstalling them and try starting it. Not a perfect solution, but I probably did that 3 or 4 times on my '33, and its been on the road 12 years now.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#3 | |
Re: 😵
