05-19-2020, 11:09 AM | #101 |
Re: Truck Caps, Camper Shells, Toppers... call them what you will, lets see them
Nice!!!!!!
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
05-19-2020, 12:03 PM | #102 |
... Click here to see thousands of 'Abandoned & Neglected' Chevy trucks rotting away... ... |
05-22-2020, 02:05 AM | #103 | |
Mahalo! |
06-11-2020, 01:47 PM | #104 | |
06-11-2020, 04:31 PM | #105 | |
06-13-2020, 06:35 PM | #106 |
period for a 79 - note this truck has only 10k miles on it too (but it was a plow truck and the chassis is very rusty).
06-19-2020, 11:03 PM | #107 |
I’m calling my “granopy” update done for now...
Repainted. LEDs. Resealed. Tinted. |
06-22-2020, 12:55 PM | #108 |
That looks awesome!
06-22-2020, 03:01 PM | #109 |
Pulled one out of a field this weekend...time for a restore...
Just a Hillbilly in the Hood http://67-72chevytrucks.com/vboard/s...d.php?t=622194 |
06-22-2020, 03:53 PM | #110 |
YEAH... Love it!!! Congrats on the find.
06-23-2020, 02:50 AM | #111 |
06-23-2020, 08:40 AM | #112 |
That really changes the attitude of the truck. Looks good.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
06-23-2020, 08:51 AM | #113 | |
I have one of these in 8ft, free to a good home. I’m in Ontario, Canada between Niagara Falls and Toronto. PM if you want it. |
06-23-2020, 03:24 PM | #114 |
I totally agree... I think campers just complete these trucks. It gives them a "used" character that the custom builds just don't have.
09-18-2020, 01:26 PM | #115 |
I picked up another one.... It is a couple inches narrow, but it works. I have another long bed one that I will probably use to modify this one. It has full length glass with a slider in the last couple feet with good screens. I really need to tint the glass though. I found it on Marketplace for $25.
09-26-2020, 08:50 PM | #116 |
Without, and with truck cap.
11-12-2020, 08:43 PM | #117 |
Scored this old girl yesterday off c-list . Off a mid to late 70's 3/4 ton truck .
Still has the makers tag and the sellers decal on each end .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
11-14-2020, 04:40 PM | #118 |
Something about this one speaks to me! Love it!
11-17-2020, 12:14 PM | #119 |
I finally got around to modifying my cap to fit my truck properly... and my needs. I pulled all the skins off to get down to the base frame and did the same to the other cap that I had. I cut out pieces of the framework from the parts cap to widen the one I will be using. There were even some angle aluminum that worked perfectly to join everything together. I widened it 2".
Since I was here and had a camping trip planned I figured that I might as well insulate the cap while I had it all apart. I used the skin from the parts cap to make an inner skin to trap the insulation. I had some 2" foam so I made a hot wore cutter with a saw horse, a couple screws, some .035 mig wire, and a battery charger. I ripped the foam down to 1" and put it between all the supports. A couple thousand screws later and a bunch of screwing around cutting and fitting pieces of aluminum it was done. I picked up some static cling window tint to add some privacy. That **** is garbage. I should have just got normal adhesive stuff, but it does it's job for now. It worked great camping. The temps were down around 30 degrees and it stayed nice and warm in there. I built a mattress platform to get above the wheel well so it was a bit tight to the ceiling, but that helped to keep it warm.
11-20-2020, 12:38 PM | #120 | |
11-21-2020, 04:49 PM | #121 |
I may have posted this before, but I got a shell that was wrecked for free and tore it all apart like that and re-arched the bent ribs and bought new sheet metal for the roof and plexiglass for the rear window. I spent a bunch also on nuts/bolts/washers and corner brackets to put the frame back together.
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
11-25-2020, 04:27 PM | #122 |
Can someone give me an idea of what these aluminum or fiberglass toppers weigh? Could I remove and install one on a longbed truck in just a few minutes by myself? Or are they too heavy for that? I'm not a gym rat, but I'm definitely not feeble either, if that makes a difference.
I really like the concept of a topper to keep my collection of toolboxes dry, particularly for those sudden summertime thunderstorms. But I also intend to use this truck regularly with a gooseneck trailer. I'm just wondering if it will be feasible to remove/reinstall the topper on a weekly basis.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
11-25-2020, 05:41 PM | #123 | |
11-25-2020, 05:49 PM | #124 |
Thanks for the reply! How are they typically fastened? Is it just a handful of bolts through the bed rails, or is there some sort of quick attach system that works well? Would Jeep hood straps work, by any chance?
11-25-2020, 06:39 PM | #125 | |
I would say aluminum cap is closer to 125 pounds, its manageable by 1 person, 2 is ideal As for attaching, you could drill and use bolts, but they make these aluminum C-clmps that Are made for attaching truck caps and tonneau covers, 6 for a long bed, I think last I'll checked it was around $30 for a set of 6 |
