01-04-2023, 12:31 PM | #1 |
1971 2wd to 4wd conversion build
Saved a '71 burb from an early death as a "Crew cab" donor body a few years back.
Now, doing a 4wd / LQ9/4L65E conversion. Sourced a 8" lifted '70 4wd 'burb chassis that was modded to fit a LWB truck. Unf*cking it so 'burb body fits back on it was step one, and rebuilding everything. Last edited by C130Nav; 01-05-2023 at 12:17 AM. |
01-04-2023, 12:33 PM | #2 |
Re: 1971 2wd to 4wd conversion build
Drivers side rocker/floor. Very clean
01-04-2023, 12:38 PM | #3 |
Roamed the backroads of northern AR
01-04-2023, 12:44 PM | #4 |
3rd door rocker repair
01-04-2023, 12:46 PM | #5 |
Passenger door rocker repair
01-04-2023, 06:20 PM | #6 |
Its a Truck Thing......
I will be doing a conversion on a Longhorn. Got all my parts from a 72 Burb 4X4 that is getting beefed up.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
01-04-2023, 06:24 PM | #7 |
BlahBlahBlah
Keep the pics coming Nav, looking good so far!
01-04-2023, 09:56 PM | #8 |
Smitty,
The rear body mounts are different in truck VS. 'Burb. I'm looking for 4wd 'burb body mounts for the #4 position(above the front leaf spring mount) forward of the rear axle. Since you won't be using them when mounting the Longhorn bed, I'll buy them from you when you remove them. Let me know Last edited by C130Nav; 01-04-2023 at 09:57 PM. Reason: Added info |
01-04-2023, 10:02 PM | #9 |
Pass rocker complete; rotted cowl spot repaired. Damn critters...🤣
01-06-2023, 01:49 AM | #10 |
Glad you saved that. Looks too clean to have been cut up for a crew cab. I like the direction that you are taking this. Will follow along for sure.
01-06-2023, 08:59 AM | #11 |
Good job!
01-08-2023, 04:33 PM | #12 |
Spent some "nasty time" on my back with a pressure pot sandblaster, doing some underfloor cleanup. Still need to get under there and touch up some areas again this week, but looking pretty clean so far.
01-08-2023, 04:41 PM | #13 |
More underfloor cleanup; qtr panel rot on pass side behind 3rd door; and pass floorboard all cleaned up.
01-08-2023, 05:29 PM | #14 |
The Older Generation
That thing still looks pretty clean. It would be nice to find one like that around here.... LockDoc
01-11-2023, 01:56 PM | #15 |
Great work! I for one are very glad you saved it.
I'm pretty sure Flynavy30 will be following your progress.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 01-11-2023 at 02:02 PM. |
01-13-2023, 07:27 PM | #16 |
Found a full front sway bar setup off a late 70s square body to install. After sandblasting crossmember and swaybar, got it all mocked up and positioned in place. Had to redrill new holes into the frame for the new crossmember and swaybar mounting brackets. Now to order new bushings all around, and get it all repainted. Will no doubt have to modify the original style front brake lines, due to different mounting angle of new crossmember.
$50 well spent 👍 |
01-13-2023, 09:09 PM | #17 | |
I was saying I was converting a 2wd Longhorn to 4WD with a suspension from a 72 Burb. I'm using the Longhorn frame and it is already leafs in the back. The whole front with mounts came off the Burb. My buddy is doing a conversion and I will see what brackets he is not using. Smitty
02-07-2023, 10:15 PM | #18 |
Been a few weeks since last worked on the truck.
Got the section between 3rd door and rear wheel replaced. Just the outer panel was swiss cheesy. Patch panel fit reasonably well; but lower contour was more curved than original. Had to make some relief cuts to make it match 3rd door rocker contour. |
02-07-2023, 10:23 PM | #19 |
Sandblasted and painted inner quarter area. Relief cuts on front of patch made it line up with rocker nicely. Welded up patch, ground it down flush, ready for a skim coat to blend in the two panels.
02-07-2023, 10:30 PM | #20 |
Next up is right rear quarter. Lots of little swiss cheese holes to fix; especially around the reverse light area. Good thing the patch panels cover that area. Didnt get the triangular rear inner patches, but will probably have to replace those as well. Wont know til old lower quarter is cut away
02-07-2023, 11:51 PM | #21 |
Lookin' good so far.... LockDoc
02-09-2023, 08:32 PM | #22 |
Cut away the bad part of the passenger side rear qtr. Still have to trim patch panel, and cut away bad reverse light area. Then sandblast away the rust, prime and paint inner qtr arwa. Will probably take out spare tire well out afterwards and blast/repaint it.
02-11-2023, 07:06 PM | #23 |
Nice work
02-25-2023, 07:47 PM | #24 |
Sandblasting and coating the understructure.
02-25-2023, 07:53 PM | #25 |
Fitting, cutting and rewelding of patch panel.
PS. It doesnt fit well around the rear area of qtr near the tailight. |
