Old 03-21-2024, 06:37 PM   #1
hewittca
hewittca's Avatar
Hairline Crack in LM7 5.3 Block
About a year ago I got this junkyard LM7 5.3 motor swapped into my truck. I did maintenance work on just about every component, but the bottom end is untouched. It has been running great for a year now and I've not had any problems with it. Then, yesterday I was underneath the truck doing some suspension work and noticed this strange wet spot on the side of the block. It was coolant but it had no source, as if it emanated from the side of the block! After cleaning it up, the spot remained dry. It wasn't until running the engine up to operating temp that I discovered there was indeed a hairline crack in the side of the block and coolant was slowly seeping out. So little that it would evaporate and dry before ever dripping on the floor. The crack is about 1" long and wraps around the vertical ridge on the block. I've drained the oil and there is no coolant in the oil, so I'm not too worried that this crack has propagated internally.
After reviewing photos from when I bought the engine, I realized that this has been leaking since before I acquired the motor as you can see a stain on the block from the leaking coolant.
At this point, I'm trying to decide what to do. I know the correct solution would be to start looking for a new block, but I'm wondering if there's anything I can do to try and stop this leak for now. I'm already in this far with this motor so what would it hurt to at least try something? Any recommendations or suggestions from the collective wisdom of this forum would be greatly appreciated!
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 03-21-2024, 08:31 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: Hairline Crack in LM7 5.3 Block
Grab yourself some of these and add to the cooling system....they will work on your tiny weep...
GM (12378255) Available fro Amazon...or GM)
5 pills per pack....follow package instructions...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 03-21-2024, 09:02 PM   #3
LS short box
All kinds of block sealant products at the local parts store. More than worth a shot instead of replacing the block.
Per my old time engine builder every chev that came off the production line had some type of coolant sealant installed at the factory.
Old 03-22-2024, 09:35 AM   #4
Willie Makeit
Willie Makeit's Avatar
it looks like someone installed a head bolt with water or oil in the hole. the bolt pushing down on the water/oil caused a hydraulic pressure spike and cracked the block.
Willie Makeit is offline   Reply With Quote
Old 03-22-2024, 01:22 PM   #5
bnorth
I would clean it up and try some JB weld. Failing that I would grind it open a little and weld it.
1970 C10 l/b 292/4spd
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=811062
bnorth is offline   Reply With Quote
Old 03-23-2024, 08:28 AM   #6
87max
87max's Avatar
went through a similar scenario years ago, Had a pro welder try to weld a hairline. After hours of attempts we never got it sealed. Naturally we cleaned it several times before hand. Tried jb over the welds- nope. For the additives some swear they will partially clog up radiator & other components. It has to go somewhere right? In the end drove it till it died & a buddy bought it & dropped in a diesel.
87max is offline   Reply With Quote
Old 03-23-2024, 08:56 AM   #7
hewittca
hewittca's Avatar
Thanks for the suggestions everyone. I have heard that it is difficult to weld a crack like this, so I probably won't try that.
I bought some of those tablets mentioned, but have not dropped them in yet. I had someone else mention that they could gum up spark plugs if there is an internal leak. My thinking is if that's true, then at least I'll know it's leaking internally as well and I should really start looking for a new block.
If I drop the tabs in, I'll probably also slap some sort of epoxy on the outside as well. I'll update once I try a few things and let you all know what happens!
Old 03-23-2024, 07:06 PM   #8
MySons68C20
MySons68C20's Avatar
The epoxy is a waist of time imho. I had a 6.9 Ford diesel delivery truck and a 2001 Duramax that both developed coolant leaks due to failing head gaskets or?
I used the Bar"s Leaks product and it fixed both and did not plug up the radiator or cause any cooling problems.
The main thing is you need to follow the instructions on the bottle to a T.
MySons68C20 is offline   Reply With Quote
Old 03-25-2024, 02:15 PM   #9
THI
Active Member
THI's Avatar
https://www.summitracing.com/parts/m...iABEgInZPD_BwE
I used this on a 350 Vortec that had cracked heads, it worked great. I was told to try that by a machine shop owner, he used it on a 400 SBC dirt track engine that he ran for three years before he over revved it and put a rod through the side of the block!
THI is offline   Reply With Quote
Old 03-25-2024, 03:27 PM   #10
bnorth
Says it's not compatible with anti-freeze
Old 03-25-2024, 03:43 PM   #11
THI
Active Member
THI's Avatar
You drain the system, use water only and run according to the instructions, after that go back to the anti-freeze solution.
Old 03-25-2024, 05:05 PM   #12
AussieinNC
Moderator
AussieinNC's Avatar
The GM tablets I listed are compatible with antifreeze and will not clog the cooling system.
They are used by GM when tiny cracks develop in castings etc...they work !
They wont impact spark plugs, the flame front in the chamber will actually set the material harder...
2012 Chevy Equinox
Old 04-04-2024, 08:00 AM   #13
hewittca
hewittca's Avatar
I wanted to update this thread to add a resolution to this issue. I decided to go with the GM tablets as a first attempt. I dropped 3 tabs in the radiator and let my truck idle up to temp. Directions call for adding the tabs with new coolant. I just put new coolant in it two weeks ago when I swapped the radiator, so I figured it was still "new". After warming up, I saw only the slightest hint of moisture coming from the crack. Next, I went for a 30 minute drive and then let the truck cool down. After subsequent drives I have not seen any coolant whatsoever. It appears that these tablets have done the trick, at least for now!
Old 04-04-2024, 05:01 PM   #14
LS short box
Very cool.
Old 04-04-2024, 07:50 PM   #15
AussieinNC
Moderator
AussieinNC's Avatar
Glad for the progress....
I use these tablets in both of my LS powered rides and have had zero issues.
I believe they were originally formulated to seal small cracks in the alloy heads, but they work on cast iron very well...
I add new tablets about every six months to ensure the continuing protection.
2012 Chevy Equinox
