06-12-2011, 07:04 PM | #1 |
"squeaky" leaf springs
Got an issue that I've not run across before, the leaf springs on my '05 GMC have started "squeaking" as of late. Tried experimenting with a bit of white lithium grease on the spring mounts/shackles with very little luck. I've owned at least 5 trucks with leafs in the rear and this is the first time I've had this issue. I'm scratching my head.
advice? thoughts? suggestions? |
06-12-2011, 08:35 PM | #2 |
Re: "squeaky" leaf springs
My 98 used to do that on the front and rear suspension components. I used a liberal amount of white lithium on all of the rubber stuff and it would take a few days to work into the parts, then it would last a month or so. I drive down a lot of white rock roads though, so it kinda comes with the territory.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! |
06-12-2011, 10:05 PM | #3 |
Happy to be here
Are they stock bushing? You know the problems associated with urethane bushings, but I have not heard of this with stockers.
06-12-2011, 11:12 PM | #4 |
they are stock on the front hanger and McGaughey's shackles in the rear - unsure what they put in their shackles ... but the weird part is the squeaking seems to be coming from BOTH ends.
06-13-2011, 11:25 AM | #5 |
Happy to be here
I'll bet the McGaughys are urethane. Sounds like your going to need some Polyurethane lube
