Old 10-28-2013, 01:27 PM   #101
JustN
Re: True C5 Rear Disc w/ internal parking brake in the works
Can you also use Camaro/Cts calipers with this kit or just vette
JustN is offline   Reply With Quote
Old 10-29-2013, 12:33 PM   #102
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
I dont know. If the caliper bracket is threaded like the Corvettes, more than likely its the same. I cant guarentee it since I didnt design the brackets for anything else. IF the cts calipers are like the F-body brackets (main bracket of the caliper is not threaded then i'd say no. You would have to do some leg work to see if it fits. Or just give it a try.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 10-29-2013, 07:51 PM   #103
JustN
ok imma think about it and get with you soon
Old 12-10-2013, 01:32 AM   #104
jimdaug
Excellent job!
I'm interested in doing this mod on a 1970 C10. Actually, I was inspired a few weeks ago by your thread on pro-touring using the LS1 brakes and was disappointed when the thread ended with you putting the Dodge brakes on. I've been trying to figure out how to do the conversion since then. Now it's a couple of weeks later, and I found this thread and the one on Full Size Chevy. What an Awesome solution.
I'm guessing the Corvette backing plate works a little better because you're using those three holes the 'vette hub bolts into instead of having to re-drill the 12 bolt axle flange.
I just finished my first basic CAD degree so I'm intimate with AutoCAD and Inventor and can probably re-create something similar. Also, I'm thinking about trying to use either 'vette J55 13" rotors, or Avalanche 1500 13" rear rotors which are 6x5.5 already so I wouldn't have to get new axles. But the Avalanche rotors are a LOT deeper than the 'vettes, 3.75" compared to less than 2".
That being said, I don't know if JustN got your last kit or not. If not let me know. Something readily available is more desirable to me than having to find a machine shop around Plano, TX. There don't seem to be that many.
Again, nicely done.
-James
jimdaug is offline   Reply With Quote
Old 12-10-2013, 01:40 AM   #105
JustN
no i didnt get em
Old 12-10-2013, 01:41 AM   #106
jimdaug
Ah. I might get lucky then.
Old 01-19-2014, 11:51 AM   #107
bbbc10
Diggin The SquareLife
these work with c6 rears?
bbbc10 is offline   Reply With Quote
Old 01-20-2014, 11:23 AM   #108
87chevy.com
They were designed for the c5/c6 brakes. The calipers are interchangeable, c6 are stiffer/stronger. Rotors are the same diameter, and thickness differences is the depth. Enough shims are supplies to go either way. I forgot which rotors i chose to install but either way the 5x5 bolt pattern needs to be drilled to the rotor
Clint
Ps the dodge brakes worked awesome, just no parking brake. Need 17" wheel minimum.
Old 01-24-2014, 12:37 AM   #109
whitedog76
Go to the GM dealer and have them look up the disc brake bracket setup for a 99 and newer truck. I'm sure it'll be less than $100 a side. You can get the rest of the components at Rockauto or your FLAPS. You'll have to drill the rotor for 5 lug though.
I spec'd this kit for a 2500 series truck, it was only $60 a side. The shoe, hardware and backing plate was only like another 30-$40.
http://s1074.photobucket.com/user/wh...83557604518159
whitedog76 is offline   Reply With Quote
Old 01-24-2014, 01:03 AM   #110
jimdaug
Have you actually installed it yet? Do the axle flange patterns match?
Old 01-24-2014, 09:27 AM   #111
greystoke
will these brackets work on a 93 C1500?
"Fear makes the wolf look bigger"
http://67-72chevytrucks.com/vboard/s...d.php?t=305629
greystoke is offline   Reply With Quote
Old 01-24-2014, 10:20 AM   #112
aggie91
I'm just glad to be here!
aggie91's Avatar
I don't believe they will, the flange on the 88-98 rear end housing has a different bolt pattern.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-24-2014, 10:52 AM   #113
whitedog76
You can call these guys and they'll make you a flange to weld onto your axle.
http://www.theshimshack.com/how-it-works
On the other hand, you could always use the S10/Blazer or Impala SS setup. I'm sure you could source the same components from GM
Their's more than one way to skin a cat.
Old 01-24-2014, 11:28 AM   #114
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by whitedog76 View Post
......Their's more than one way to skin a cat.
I have always wondered why you would want to skin a cat? I mean its gotta be a heck of a job to get them to hold still that long.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-24-2014, 01:02 PM   #115
ERASER5
ERASER5's Avatar
Getting them to hold still is easy after you make them blink with a ball pean hammer...or so I've heard.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 04-11-2015, 10:06 PM   #116
87chevy.com
Here are some pictures of the parking brake cables I wound up using. I'll post part numbers once I fire the laptop up..
Showing the back side of the bracket.. This way only one additional hole needs to be drilled into the stock frame bracket.
Showing use of the cable holder
Lost the other cable holder and only had 1 set left for the last kit.. So used the factory cable spring lock retainer
Shows cable routing with a cable bracket bolted to the driver lower shock bolt.
Old 10-18-2019, 08:44 AM   #117
BigTopGT
Active Member
Bringing this one back from the dead.
Did this ever make into production?
I’ve got a 67 C20 AND a complete C5 brake setup. (pads, calipers, rotors) I’d love to use on the old girl.
BigTopGT is offline   Reply With Quote
Old 10-21-2019, 02:02 PM   #118
87chevy.com
I did a small run of 6 or so years ago and took quite a while to sell even at a cheap price of 180 back then. Since then I've only been asked 2-3 times. If I could get 6 people interested I can get requote and go from there.
Clinr
Old 10-22-2019, 08:22 PM   #119
BigTopGT
Active Member
Clinr
When you have a second, can you shoot me a pm to discuss this setup?
I’ve got a few questions about the setup I have now and what I’d need to get in preparation for the upgrade with your parts.
Old 10-24-2019, 09:57 PM   #120
STICKBNDER
Clinr
what do you figure the whole setup would run?(ball park)
STICKBNDER is offline   Reply With Quote
Old 10-25-2019, 10:54 PM   #121
87chevy.com
Rockauto, O'Reilly, autozoney, kore3.. friend parting out car...junkyard .. near free to 999$ + more research = cheaper price... brutal but honest
