01-07-2015, 03:31 PM | #1 |
Nv4500
what is the shortest nv4500 to use with a divorced t/f case. the dodge 2wd looks longer than the chevy 2wd? Would like to use my stock bell with an adapter. a chevy with the dodge in put?
1961 chevy K10 my build is------------61K10 build |
01-08-2015, 11:52 AM | #2 |
Re: Nv4500
I think a chevy with a dodge gas input, then you could use an A/A adapter and keep the cast iron bell, but it woul have to be bored out to 5 1/8. Or have your own adapter made. I have a cast iron bell with 5 1/8 bore already and this is what i will do some day.
63 k20 with cummins 4bt, owned sence 1982 |
01-08-2015, 01:40 PM | #3 |
Re: Nv4500
thanks for the reply--must be getting old, thought i put this in the 4x4 section not the 4x4 builds.
01-15-2015, 04:29 AM | #4 |
Re: Nv4500
Another member on here was successful in in doing a transfer punch from his bellhousing and drilling new holes in the nv4500 case. He was using a later aluminum bell, so as dieseldude said youd also have to bore out the center hole to fit the nv4500. This would allow you to just bolt on a chevy nv4500.
The 92-95 chevy housings use a different bell bolt pattern than 96 and up chevy, and dodges. Luckily since you are using a 2wd version you wont be concerned that chevys have 32 spline outputs while dodges use 27 spline.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
01-15-2015, 04:36 AM | #5 |
Re: Nv4500
You might also give thought to swapping the T221 out for a Dodge divorced NP205. It would be quieter and parts are far more easy to come by.
I've looked at them and I think you could do it with simple mods to the 221 mount brackets. It would however increase your rear driveshaft angles.
01-15-2015, 06:23 PM | #6 |
Re: Nv4500
The gm 2wd fixed yoke 35spline has a 6" tail housing which is 7" shorter than the dodge version.
I have the some pics of this set up ,I will post them when I find them. Scott
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
01-15-2015, 08:24 PM | #7 |
Re: Nv4500
As argonaut suggests, the early GM NV4500s used a trans bolt pattern the same as earlier manual transmissions. They also have an unsynchronized 1st like the SM420 and SM465, while the 96 up had a 5.6:1 or so 1st, which isn't much different.
01-16-2015, 02:43 AM | #8 |
Re: Nv4500
wait, I want to correct something. I have both a 92 and a 95 chevy nv4500. while this pattern is different from the late pattern, it IS NOT the same as the early chevy 4-speed patterns.
Also the output spline counts that I listed were for 4wd transmission outputs, not 2wd. So those may not apply.
01-23-2015, 01:53 PM | #9 |
Re: Nv4500
Thanks for all the info--so a chevy 2wd with the 6" tail, what is the total length?
02-08-2015, 04:13 PM | #10 |
Re: Nv4500
Here is the pics of the Nv4500 I installed in the dodge power wagon.
02-09-2015, 01:51 PM | #11 |
Re: Nv4500
Crew-- that looks pretty short, any measurement (total length) specs. of trans? and thanks for the pic.
02-09-2015, 02:17 PM | #12 | |
Re: Nv4500
The Nv4500 main case is 12.375" plus the Gm 6" fixed yoke. The Nv4500 in above pic. Gm 96 and newer,w/Gm shifter stub. Fixed yoke 6" ,w/35 spline output. Cummins input and bearing retainer. I use this set up in all my Cummins conversions when I need a divorce t-case or in any2wd.The E-brake drum can be added as well. Hope this helps.
02-14-2015, 01:55 PM | #13 |
Re: Nv4500
Thanks crew for the info.
