Old 03-17-2021, 09:44 PM   #1
60short
60short's Avatar
Replacement Steering Column
Hey All,
My beloved truck (1960 C10 with manual steeting) has started to make some grinding noises in the column - sounds like the bearings may be going - I haven't been able to locate both of them for the 1960 MY and this column is missing turn signal components, horn contacts and used to be a column shift (since converted the the floor)
Being junkyard challenged and without major fabrication tools, I am thinking about swapping in a new steering column, and I have questions for those of you that have done the swap.
1. does anybody have a preferred brand - I've heard good things about Ididit and Flaming River ( I also heard summit's house brand is Ididit produced?)
2. has anybody that has replaced their column - do you know / re-call what length you used?
3. has anybody kept the large diameter steering wheel on a new column? I want to keep manual steering at the moment.
Thanks,
Keith
1960 C-10 Apache- "Rusty the Redneck Reject"
1/2 Ton short bed step side.
350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs
20+ year long term project in process
Lots of Rust, more memories...
60short is online now   Reply With Quote
Old 03-22-2021, 08:10 PM   #2
chevykevy
chevykevy's Avatar
Re: Replacement Steering Column
I have used a column from a 67-70 with an automatic. I liked the steel indicator bezel ....looked more period than the plastic on the 71-72.
Good Luck
chevykevy is offline   Reply With Quote
Old 03-28-2021, 01:04 PM   #3
meinolf
hi keith, ich schreibe auf deutsch du hast keine möglichkeit ein manuell collumn neu zu kaufen das habe ich auch versucht ich habe dann umgebaut auf floor shifter
gruß from black forest germany olf
meinolf is offline   Reply With Quote
Old 03-28-2021, 01:07 PM   #4
meinolf
bilder
Old 03-28-2021, 01:13 PM   #5
61hawk
61hawk's Avatar
All I understood was "floor shifter".
61hawk is offline   Reply With Quote
Old 03-28-2021, 01:48 PM   #6
meinolf
google translate german-englisch
bearing, column, replacement, steering
