06-01-2021, 09:59 AM | #1 |
door to fender alignment - 71 4wd Blazer - pix inside
I'm having some trouble aligning the front of the door to the rear of the front fender on the passenger side of my blazer project - larger gap than I would like at the top where the cowl panel meets.
I have tried using both the OEM fender that was on it before I started and a replacement fender and they are both similar in fit - so thinking I may need to pull the door forward in the opening (toward the hood), but that will throw off the gap to the rear quarter.
Some before/after pix for reference. My options appear to be:
06-01-2021, 10:24 AM | #2 |
Re: door to fender alignment - 71 4wd Blazer - pix inside
I,m having the same trouble with my 78 blazer, really fighting me. Truck was easier. Wonder if it,s a Blazer thing. Anyway I,ve watched a build thread on u tube called Baily,s build and he did a show on his door gaps and he had to add material or take some off on his fender or door. Just the bad aftermarket parts I would think.
06-01-2021, 11:55 AM | #3 |
I am just guessing and do not really know.
How does the windshield gap to door frame look at the top? Adding a shim to the footwell body mount will close it. Adding one to the next location would open it. If you have extra shims cut a slot in them so you do not have to remove the bolts to install and remove them. Once you get the B pillar and windshield to door as close as you can move to the fender. If needed you might have to shim the core support up to close that top gap if it remains after everything else?
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
06-02-2021, 01:17 PM | #4 |
Factory gaps were not as perfect as we would like to think, then mixing and matching parts adds to the variables.
If you are a metal guy you could add a strip to the door to fill the gap but that is a lot of work. When I use an aftermarket fender I slot all the bolt holes to give me that little bit more. I'm gathering all the parts now to switch my 72 back to a 72 from a 68 front clip. The gaps now are not good and I am worried they will get worse. When you figure it out, please share. Good luck. Scott |
06-02-2021, 01:41 PM | #5 |
I used a repop fender on my blazer back in the day, it was unreal how far off the mounting holes were...had to do alot of slotting...
Like Scott said..factory gaps were far from perfect
06-02-2021, 06:51 PM | #6 |
Thanks for the replies all - I mocked up the driver side and that is much closer top to bottom between the fender and door. I do need to open up the lower fender opening to allow the lower fender to ease down a bit at the style line.
Any shifting I thought I could do in the front clip (to close the gap on the pass side) may need to be reconsidered so I don't mess up that side making adjustments. |
06-03-2021, 08:45 AM | #7 |
Looks good to me; ship it!
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
