Old 01-18-2022, 09:57 PM   #1
forestb
forestb's Avatar
Drilling through carpet
I wold like to drill a hole in some sheet metal that is covered in carpet and insulation. Is there some kind of special drill bit or tool that would allow be to do so?
forestb is offline   Reply With Quote
Old 01-18-2022, 10:01 PM   #2
SkinnyG
SkinnyG's Avatar
Re: Drilling through carpet
I've seen people heat up a piece of metal tubing to sear through the carpet where the bolt holes go, which should stop it from catching and unraveling.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 01-18-2022, 10:38 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
I use a flame heated soldering iron, but yes same idea.
Old 01-18-2022, 11:38 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
Go up to the local hardware store and buy a set of hole punches. Punch through the carpet and then drill the holes. Speaking as a guy who as a young 'un wound carpet around a drill bit and stripped a nice bit of carpet...
~Steven
Simi Valley, CA
Old 01-19-2022, 12:54 AM   #5
oem4me
No guarantees, but you could try running a standard drill bit in reverse until it burns though the rug and pad, then forward through the metal. I've done this in a pinch, but not my first choice. Good luck!
Old 01-19-2022, 07:00 AM   #6
geezer#99
geezer#99's Avatar
Wrap some electrician’s black tape around it. Leave a 1/4 inch of the bit exposed.
Old 01-19-2022, 11:34 AM   #7
forestb
forestb's Avatar
To be on the safe side I might try a combination of these suggestions. Hole punch, heat up the fibers and then wrap the bit in electrical tape. I learned the hard way not to just go for it. I ended up with a broken drill bit that I could not get out of the carpet so I just had to leave it in there. That was years ago and the carpet has sense been replaced.
Old 01-19-2022, 11:35 AM   #8
vin63
It's Better With Nitro
vin63's Avatar
I use my soldering iron to poke holes through the carpet.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-19-2022, 11:37 AM   #9
forestb
forestb's Avatar
toooo many options
Old 01-19-2022, 03:45 PM   #10
The Rocknrod
Moderator
Not really try one idea on each hole to see how you like it.
Old 01-19-2022, 05:09 PM   #11
bigmoe
bigmoe's Avatar
I clamp a nail in some vice grips, heat up the nail, poke into the carpet and wiggle the nail around to make the hole a bit bigger. Then drill it.
I use the same nail trick from the bottom when there's already a hole in the metal.
bigmoe is offline   Reply With Quote
Old 01-19-2022, 09:02 PM   #12
MT65
I have done this many times, 3/8 hardline , bevel the edge, heat it up and it works great….
MT65 is offline   Reply With Quote
Old 01-19-2022, 10:11 PM   #13
Richard
After a hole is made in the carpet cut a piece of tubing with an inner diameter slightly larger than the drill bit. Tubing should be long enough to hold tight but short enough for bit to go through. Work end of tubing into carpet hole and hold tight to metal while drilling. Not a bad idea to use the same piece of tube to burn a hole through the carpet as previously suggested.
Richard
Old 01-20-2022, 02:00 PM   #14
jweb
jweb's Avatar
If possible drill from the metal side, hen use a soldering iron or awl to poke the hole through.
1951 Truck, LS1/4L60
1964 Suburban, current project
2014 Silverado daily driver
1953 Westerner "canned ham" trailer, rebuilt
1974 Prowler trailer, rebuilt
jweb is offline   Reply With Quote
Old 01-20-2022, 09:51 PM   #15
slepysal
slepysal's Avatar
As mentioned an old soldering iron works great. As an added tip use a pick to located your holes then insert hot soldering iron and move it around to make your holes no frayed carpet. This is what I did to install my seats after my carpet install.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 01-24-2022, 12:18 PM   #16
LT1 Burb
LT1 Burb's Avatar
I use a gasket making punch.
LT1 Burb is offline   Reply With Quote
Old 03-14-2022, 09:43 AM   #17
old51sedan
old51sedan's Avatar
Back in the 60's working at Sears people would buy seat belts for their cars and of course want them installed. I didn't want to use a drill because of the carpet so I asked one of the old boys working there. He went to his tool box and brought back a large round tapered drift about 6-8 inches long, but it right where I wanted the hole and gave it a bid whack. It went through the carpet, pad, and the floor. As a matter of fact I used the same method a few years ago installing seat belts in my 51 sedan. Easy- peasy as they say.
old51sedan is offline   Reply With Quote
Old 03-14-2022, 03:11 PM   #18
88Stanger
88Stanger's Avatar
i have used a hole punch kit that I heated up with a torch, worked perfect for me.
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 03-14-2022, 08:32 PM   #19
franken
I got the carpet where I wanted it, then from the underside pushed a $4 HF soldering iron up through the bolt holes.
